6 Replies Latest reply on Sep 26, 2008 10:39 AM by MohaviRazavi
    File Size Change--Why?
    MohaviRazavi
      We use RoboHelp to create HTML help for our clients. After we compile a help subsystem, we crush the compiled help into a single ".CSH" document.
      Each time we crush one of our help subsystems, the size of the final crush file changes slightly. For example, if I crush EDhelp on Monday, the EDhelp.CSH file might show as being 6,050 KB. If I recompile and recrush on Wednesday, the final crush file might show as 6,100 KB. It makes sense to me that the crush file will enlarge as we add more topics to the EDhelp subsystem.
      Here's the catch: A client is reporting that our crush files sometimes DECREASE by about 200 KB between deliveries, even though we are not removing help topics. When I compare the number of folders and documents in the help project to an older version, I see nothing missing. The help appears to work fine, but the client worries that something is missing.
      Does anyone have any idea why the size of a crush file would be reduced by about 220 KB from a previous crushing of the file, when the files being crushed have not been reduced?
      Thanks!
        • 1. Re: File Size Change--Why?
          RoboColum(n) Level 5
          Hi MohaviRazavi and welcome to the RH community.
          I suspect that no one answered your previous post because they were not sure what you meant by "crushing" a file. I'm assuming you are talking about a Unix command that is similar to compressing? To be honest I have no knowledge of just how any compression tool works and quite frankly I don't want to. What I want to know is that it works.
          Is it a problem for your users or are they just curious?
          • 2. Re: File Size Change--Why?
            Hi all
            Like Colum, I inferred that crushing was akin to zipping a file. Using some form of file compression utility to make it smaller.
            As long as the end resulting file works, there should be no need for worry or cause for alarm with a size difference. These beasties use different algorithms to compress the data. Perhaps something in the source files was rearranged a smidge that resulted in better compression occurring where it wasn't before and that accounts for the decrease in size.
            Just my $.02 worth. I suppose when adjusted for current events, it may be my $.0000002 worth.
            Cheers... Rick
            • 4. Re: File Size Change--Why?
              MohaviRazavi Level 1
              Thanks for the input. Yes, I am talking about compressing files into a .CSH file. It's how we deliver help files to our customers. Once, we did deliver a file that did not compile correctly, so when it was "crushed," folders were missing. Now the client is hyper-aware of that and compares the size of each delivery against the previous delivery, which is why they noticed that previous deliveres of a .CSH file might be larger than the current delivery by as much as 200 KB. I see nothing missing in the files themselves, but every time this happens, they ask us why, so I'd like to provide a reasonable answer.
              Thanks again for your help.
              • 5. Re: File Size Change--Why?
                Rick's suggestion about the compression algorithm is the way I'd go. I might also politely suggest that if I spent more time producing the documentation and less time firefighting non-existent problems that there would be less likelihood delivering help files that didn't compile properly.
                • 6. Re: File Size Change--Why?
                  I so hear you. Thanks!
