13 Replies Latest reply on Jun 25, 2009 11:17 AM by kglad
    LoadMovie question
    mentlity Level 1
      I have an flv player inside an swf (call it sub1.swf) the flv player has xml files that need to be in the same folder in order to work. I use a main swf to call the flv player  that is inside the sub1.swf with loadMovie this works fine as the path is  (in main.swf) loadMovie("sub.swf",1);
      My problem is I have 8 other sub swf pages with 1 flv player in each and I cannot put these sub .swfs in the same folder as sub 1 because the xml files all have the same names and this will cause none of them to work. My only other idea is to put each sub.swf with xml and flv player files in its own folder so I have 9 folders with 9 separate sub.swfs. So the path is
      (in main.swf)
      loadMovie("folder1/sub1.swf",1);
      loadMovie("folder2/sub2.swf",1);
      loadMovie("folder3/sub3.swf",1);
      This does not work,there has to be another way to do this.
      anybody?
        • 1. Re: LoadMovie question
          use loadMovieNum() if you want to load into levels and use different levels for each swf.
          loadMovieNum("folder1/sub1.swf",1);
          loadMovieNum("folder2/sub2.swf",2);
          loadMovieNum("folder3/sub3.swf",3);
          • 2. Re: LoadMovie question
            mentlity Level 1
            OK, but loadMovieNum does not work when the path is
            loadMovieNum ("folder1/sub.swf",1)
            only works for
            loadMovieNum ("sub.swf",1)
            when I put the folder1 the swf is in (in the path) it doesn't work.
            • 3. Re: LoadMovie question
              then you have the wrong folder name or the wrong swf name or the others are loading and you don't see them.
              p.s.  the path will be relative to the embedding html file.
              • 4. Re: LoadMovie question
                mentlity Level 1
                Gotta be something as I tried this with separate swfs and still get
                the same thing. Just to make sure here is another scenerio which I tried
                loadMovieNum("resume.swf",1); works fine.
                if I take resume.swf and put it in a folder called xxx so I have
                loadMovieNum("xxx/resume.swf",1); this does not work
                the action is in the first frame of my main.swf which just has the
                action in the timeline and nothing else it loads resume.swf into level1
                • 5. Re: LoadMovie question
                  is xxx a subfolder of the folder that contains your main (the one with the loadMovieNum code) swf and the embedding html?   are you testing by opening the html in your browser or in the test environment?
                  • 6. Re: LoadMovie question
                    mentlity Level 1
                    main.swf (main movie)
                    sub1.swf (movie loaded into level 1 of main)
                    xxx is folder that sub1.swf is in.
                    and just to be sure I changed swfs to the following:
                    main.swf first frame action    loadMovieNum("resume.swf",1); works fine.
                    I'm trying in the test environment.
                    • 7. Re: LoadMovie question
                      what does resume.swf have to do with this?
                      • 8. Re: LoadMovie question
                        mentlity Level 1
                        resume.swf is a total differerent file. I used it to make sure that it
                        wasn't an error in sub.swf",1)
                        to clear up any confusion
                        LoadMovieNum ("sub.swf",1) works
                        LoadMovieNum ("folder1/sub.swf",1) DOES NOT WORK
                        rder
                        • 9. Re: LoadMovie question
                          double check your spelling on the folder name(s).  if you're certain folder1 is spelling correctly, zip you fla, swf, html and folder1 along with sub1.swf and attach it to this forum or upload it a server and post a link.
                          • 10. Re: LoadMovie question
                            mentlity Level 1
                            http://www.dagwaremedia.com/loadmovie_tests.zip
                            The link above will download a zip with the following inside
                            main_w_folder
                            AC_RunActiveContent
                            .fla
                            .html
                            .swf
                            main
                            .fla
                            .html
                            .swf
                            sub1
                            .fla
                            .html
                            .swf
                            xxx -folder
                            AC_RunActiveContent
                            sub1
                            .fla
                            .html
                            .swf
                            All I need to do is to correctly code the path so I can use loadMovie to open a file. The loadMovie action is in frame 1 of main.swf
                            As stated in previous posts
                            loadMovieNum("sub1.swf",1); works fine
                            but I need to open from within another folder like this
                            loadMovieNum("xxx/sub1.swf",1); this does not work
                            It has to be the way I'm coding as I tried this in both running from a desktop and with the files on a server..
                            • 11. Re: LoadMovie question
                              why is that you think
                              does not work
                              • 12. Re: LoadMovie question
                                mentlity Level 1
                                Very strange! I just tried the exact file I made and it now works, I'm
                                not gonna even think about why it wasn't working before. So just to be
                                safe I'm going to make sure I refresh all files as I see it is working
                                now.
                                Sorry about the stupidity
                                rdefr
                                • 13. Re: LoadMovie question
                                  you're welcome.
