6 Replies Latest reply: Jul 3, 2009 3:38 PM by the_missing_link RSS
    Creating a login\register form in DW and xampp mysql will only hold one query?? help please.
    the_missing_link Community Member
      Hi;
      I have been doing a lot of research on how to code in php and mysql. I've read one of david powers books that has a few chapters on DW and php but I've also been watching tutorials at lynda.com. Whenever I make a form and I connect to my mysql database via xampp it will only hold one username  at a time in the mysql database. I'm trying to figure out if this is a problem with the php or if somethings wrong with my database settings. I will gladly copy over the DW php form and anything from my mysql database.  I know the form is currently susceptable to mysql injections thats cause the versions I will display won't show the security codes because I learned that from Mr. Powers book. I didn't follow his security tutorial to a T-- I did change some variable names but I don't want to risk infringing on any of his rights.
        • 1. Re: Creating a login\register form in DW and xampp mysql will only hold one query?? help please.
          David_Powers CommunityMVP
          The code printed in my books is there for readers to use. You're not infringing my rights by using code that I have released to the public.
          • 2. Re: Creating a login\register form in DW and xampp mysql will only hold one query?? help please.
            Thank you david. here is the login code with the security <?php virtual('/Connections/userinfo.php'); ?>
            <?php
            if (!function_exists("GetSQLValueString")) {
            function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
              if (PHP_VERSION < 6) {
                $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
              $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
              switch ($theType) {
                case "text":
                  $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
                  break;
                case "long":
                case "int":
                  $theValue = ($theValue != "") ? intval($theValue) : "NULL";
                  break;
                case "double":
                  $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
                  break;
                case "date":
                  break;
                case "defined":
                  $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
                  break;
              return $theValue;
            mysql_select_db($database_userinfo, $userinfo);
            $query_user_info_registration = "SELECT * FROM user_info_registration";
            $user_info_registration = mysql_query($query_user_info_registration, $userinfo) or die(mysql_error());
            $row_user_info_registration = mysql_fetch_assoc($user_info_registration);
            $totalRows_user_info_registration = mysql_num_rows($user_info_registration);
            $editFormAction = $_SERVER['PHP_SELF'];
            if (isset($_SERVER['QUERY_STRING'])) {
              $editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
            if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form2")) {
              $insertSQL = sprintf("INSERT INTO user_info_registration (user_id, username, password, email, firstname, lastname, gender) VALUES (%s, %s, %s, %s, %s, %s, %s)",
                                   GetSQLValueString($_POST['user_id'], "int"),
                                   GetSQLValueString($_POST['username'], "text"),
                                   GetSQLValueString($_POST['password'], "text"),
                                   GetSQLValueString($_POST['email'], "text"),
                                   GetSQLValueString($_POST['firstname'], "text"),
                                   GetSQLValueString($_POST['lastname'], "text"),
                                   GetSQLValueString(isset($_POST['gender']) ? "true" : "", "defined","'Y'","'N'"));
              $Result1 = mysql_query($insertSQL, $userinfo) or die(mysql_error());
              $insertGoTo = "/planet_zuda/welcome.php";
                $insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
                $insertGoTo .= $_SERVER['QUERY_STRING'];
              header(sprintf("Location: %s", $insertGoTo));
            if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
             //show array error messages
            $error = array();
            // remove whitespace
            $_POST['Username'] = trim($_POST[Username]);
            $_POST[first_name] =  trim($_POST['first_name']);
            $_POST['Last_Name'] = trim($_POST['Last_Name']);
            if (empty($_POST['first_name'])|| empty($_POST['Last_Name'])) {
            $error['name'] = 'Please enter  your first name';
            //username security check
            $_POST['Username'] = trim($_POST['Username']);
            if (strlen($_POST['Username']) < 6) {
            $error ['length'] = 'please choose a username with 6 or more characters.';
            // checking to make sure password is valid
            $pwdvld = true;
            // trim whitespace
            $_POST['pwd'] = trim ($_POST['pwd']);
            if (strlen($_POST['pwd']) < 7);{
            $error['pwd_length'] = 'due to reasons of security please choose a password with seven or more characters';
            $pwdvld = false;
            // if passwords don't match send an alert
            if ($_POST['pwd'] != trim($_POST['retpe_pwd'])) {
            $error['pwd'] = "your passwords do not match. Please try again!";
            $pwdvld = false;
            // if users password is validated okay go ahead with enhancements
            if($pwdvld) {
            $_POST['pwd'] = sha1($_POST['pwd']);
            //if the form is completed with no errors continue with task
            if (!$error) {
              $insertSQL = sprintf("INSERT INTO user_registration (Username, first_name, Last_Name, Users_Password, Gender, e_mail) VALUES (%s, %s, %s, %s, %s, %s)",
                                   GetSQLValueString($_POST['Username'], "text"),
                                   GetSQLValueString($_POST['first_name'], "text"),
                                   GetSQLValueString($_POST['Last_Name'], "text"),
                                   GetSQLValueString($_POST['Users_Password'], "text"),
                                   GetSQLValueString(isset($_POST['Gender']) ? "true" : "", "defined","'Y'","'N'"),
                                   GetSQLValueString($_POST['e_mail'], "text"));
              $Result1 = mysql_query($insertSQL, $userinfo);
              if(!Result1 && mysql_errno() == 1062) {
              $error['Username'] = $_POST['Username'] .  'sorry this username has been taken. Please choose a different username.';
             } elseif (mysql_error()) {
              $error['dberror'] = 'Sorry, there was an error. Please try again later or email techs@planetzuda.com';
             } else {
              $insertGoTo = "welcome.php";
            <?php include("includes/body.php")?>
            <h1 class="move">register your free account<br />
            </h1>
            <p> </p>
            <form action="<?php echo $editFormAction; ?>" method="post" name="form1" id="user_info_registration">
              <input type="hidden" name="MM_insert" value="form1" />
            </form>
            <form action="<?php echo $editFormAction; ?>" method="post" name="form2" id="form2">
              <table align="center" class="zudanian">
                <tr valign="baseline">
                  <td nowrap="nowrap" align="right">Username:</td>
                  <td><input type="text" name="username" value="" size="32" /></td>
                </tr>
                  <td nowrap="nowrap" align="right">Password:</td>
                  <td><input type="text" name="password" value="" size="32" /></td>
                </tr>
                  <td nowrap="nowrap" align="right">Email:</td>
                  <td><input type="text" name="email" value="" size="32" /></td>
                </tr>
                  <td nowrap="nowrap" align="right">Firstname(optional:</td>
                  <td><input type="text" name="firstname" value="" size="32" /></td>
                </tr>
                  <td nowrap="nowrap" align="right">Lastname(optional:</td>
                  <td><input type="text" name="lastname" value="" size="32" /></td>
                </tr>
                  <td nowrap="nowrap" align="right">Gender:</td>
                  <td valign="baseline"><table>
                    <tr>
                      <td><input type="radio" name="gender" value="m" />
                        male</td>
                    </tr>
                    <tr>
                      <td><input type="radio" name="gender" value="f" />
                        female</td>
                    </tr>
                  </table></td>
                </tr>
                  <td nowrap="nowrap" align="right"> </td>
                  <td><input type="submit" value="register" /></td>
                </tr>
              </table>
              <input type="hidden" name="MM_insert" value="form2" />
            </form>
            <p> </p>
            </body>
            </html>
            <?php
            mysql_free_result($user_info_registration);
            • 3. Re: Creating a login\register form in DW and xampp mysql will only hold one query?? help please.
              You have got two forms in your page: form1 and form2. The first one, form1, does nothing. It has only a hidden field, but no submit button. Consequently, your validation code never gets run, because all the error checking is controlled by this conditional statement:
               $error = array();
               etc...
              • 4. Re: Creating a login\register form in DW and xampp mysql will only hold one query?? help please.
                Thank you for looking over the code and finding that newb error for me. I'm
                inspecting all of my php coding with a fine comb now! I know langauges being
                case sensitive is helpful but it can also be a bit of a pain... I guess I'll
                get better at it. I know form1 and form2 don't have anything to do with
                cases I'm talking about other errors I've ran into.
                • 5. Re: Creating a login\register form in DW and xampp mysql will only hold one query?? help please.
                  QiQi86 Community Member
                  Okay, first of all it's better if u delete any form that is not being used. From your code i see u have made 2 coding for insert record and both also using different table name(user_info_registration, user_registration). Which one did u exactly use and which table where the problem is happened?
                  • 6. Re: Creating a login\register form in DW and xampp mysql will only hold one query?? help please.
                    Thanks for the reply and taking the time to read all of the code! I have
                    tried to make the form work but I kinda gave up on it and started building a
                    new one so I won't run into my previous coding errors. I should have posted
                    that on the forum. Sorry sometimes I get wrapped up in my own little world
                    and forget to post. Oh to answer your question I'm using
                    user_info_registration. Again thank you for taking the time to read all of
                    the code!
