10 Replies Latest reply on Jun 25, 2009 9:54 PM by kglad
    multi-array question
    christoon_ca
      Hello
      I find this hard to explain so I will use an example...
      Here is the data:
      wir = Array("twelveVolt", "ignition", "ignition_2", "accessory", "starter", "keySense", "arm", "parkingLights", "clutchSwitch");
      dmm = Array("acv", "dcv", "ohm");
      key = Array("koff", "kacc", "kign", "kstr");
      eng = Array(wir, dmm, key);
      Here is an example with some of the above data:
      eng[twelveVolt][acv][wir] = "12";
      I have all of the data combinations, I just cannot, for the life of me, figure out how to output the data
      Any help is greatly appreciated
        • 1. Re: multi-array question
          christoon_ca wrote:
          Hello
          Here is the data:
          trace(eng[0][0]);  // twelveVolt
          trace(eng[1][0]):  // acv
          trace(eng[2][0]);  // koff;
          • 2. Re: multi-array question
            christoon_ca Level 1
            Thanks for the reply kglad. I don't think I explained myself well enough though. I gues what I'm after is something more like this:
            if (wir = twelveVolt, dmm = acv, key = koff) {
                 text.text = "12"
            but...
            if (wir = twelveVolt, dmm = acv, key = kon) {
                 text.text = "13"
            and all the rest of the combos for all the variables... Do I use a loop, or something else maybe?
            Thank you
            • 3. Re: multi-array question
              how can it be deduced that "12" has something to do with the first array elements of wir,dmm and key?
              • 4. Re: multi-array question
                kglad: Right, I would need to declare all the data first. So instead of my "if" example, I would need to declare:
                (wir[twelveVolt], dmm[acv], key[koff]) = "12";
                I don't even know the syntax for that!
                Sorry for my fuzzy head. Thanks for your help.
                • 5. Re: multi-array question
                  i have a feeling you're trying to use an associative array but, so far, i can't determine just what it is that you're trying to do.  you might try explaining what you need.
                  but, it may help you to see the following:
                  var obj:Object={};
                  // assigns "twelveVolt" as a property of obj
                  obj["twelveVolt"]="12";
                  // assigns wir[0] as a property of obj.  if wir[0]="twelveVolt", this is the same as above
                  obj[wir[0]]="12";
                  etc
                  • 6. Re: multi-array question
                    hmmm, that does help me in other area
                    I'm getting better with the array stuff as I go, but now I hit another seemingly strange wall
                    var onOff = "koff";
                    key.onPress = function() {
                        if (onOff == "koff") {
                            key.gotoAndStop ("kacc");
                            onOff = "kacc";
                        }else if (onOff == "kacc") {
                            key.gotoAndStop ("kon");
                            onOff = "kon";
                        }else if (onOff == "kignB") {
                            key.gotoAndStop ("koff");
                            onOff = "koff";
                    key.onMouseDown = function() {
                        if (onOff == "kon") {
                            key.gotoAndPlay ("kign");
                            onOff = "kign";
                    key.onMouseUp = function() {
                        if (onOff == "kign") {
                            key.gotoAndPlay ("kignB");
                            onOff = "kignB";
                    check_mc.onRelease = function() {
                        trace(onOff);
                    "check_mc" works normally until "key"  is on the "kon" frame, then when I press "check_mc" it sends "key" to the "kignb" frame. I don't get it.
                    I attached the file as well, if that's easier.
                    Thanks again
                    • 7. Re: multi-array question
                      I've just realized it doesn't matter where I click and hold down, the "key" thinks it's on "key".
                      • 8. Re: multi-array question
                        i'm not sure what you're trying to do with that code.  if you're trying to detect keyboard presses check the Key class.  you'll need to add a listener object.
                        onMouseDown and onMouseUp execute whenever the mouse is down and up no matter its location.  use onPress and onRelease to detect those mouse events when the mouse is over your object.
                        • 9. Re: multi-array question
                          thanks for the reply
                          is there no way to have an onMouseDown/Up on just a single mc? I just want to be able to hold it down, then release.
                          • 10. Re: multi-array question
                            use the onRelease method.
