1. Re: swf goes in a loop in loader component
Ned Murphy Jun 25, 2009 6:24 AM (in response to fhiol)If your slider has a rollover effect applied to it, and the thumbnail swfs are contained within that slider, then the rollover effect will mask any interactions with the swfs. What is the purpose of the rollover? Can you explain the details of your design and show the relevant code?
2. Re: swf goes in a loop in loader component
fhiol Jun 25, 2009 7:12 AM (in response to Ned Murphy)Thank you very much for your response.
I attached all files with folder structure.
That represent a simplified model of what I want to build.
The main file is demo-test.swf and sample of swf that I’m trying to use is test.swf.
I switched path from 1st image to test.swf in xml file.
As you can see test.swf loads, but it goes in a loop. and i need fully functional swf(or other format) with inner navigation.
Thank you,
Oleg
Thumbnail-Slider-V1.zip 1.7 MB
3. Re: swf goes in a loop in loader component
fhiol Jun 26, 2009 7:34 AM (in response to fhiol)The loaded swf must be an AS2 (i was trying to load AS3)
