2 Replies Latest reply on Jun 30, 2009 3:26 AM by Eli7BBB
    ResourceManager support for single-plural, feminine-masculine cases
    Eli7BBB
      Hello,
      I am developping a large scale website with support for multiple languages.
      I am using the ResourceManager to manage the switch of languages by the user. It works OK, but I have some cases where I cannot find
      a proper solution.
      I wan to display different strings for plural and single cases. For example:
      You have 1 image
      You have 3 images
      And I want to do it automatically, not through asking in the code:
      if (numImages > 1) { display (ResourceManager.getString(locale,images_string_from_properties_file)} else {
                               display (ResourceManager.getString(locale,image_string_from_properties_file)} .
      There is a solution for that using a gnu utility xgetText, where you generate for each msg-string a single and plural versions, but it does not work
      well with AS3 (or any other AS), since it is based on C. (it is explained in
      http://www.sephiroth.it/phpwiki/index.php?title=Gettext_actionscript3
      , but does not cover the problematic issues, and so has no advantage over ResourceManager).
      The same issue goes for languages where the feminine and masculine differ - like arabic and hebrew (and probably others).
      Has any one dealt with these issues before ?.
      Elisheva
