10 Replies Latest reply on Jun 25, 2009 9:58 PM by kglad
    Scripting the loading bar without a UILoader...
    cmoadobe
      So I was using a UILoader to load my swf, but was having issues with the component, so I got rid of it, and am now using the following AS to load the file instead:
      var Xpos:Number=0;
      var Ypos:Number=0;
      var swf:MovieClip;
      var loader:Loader=new Loader();
      var defaultSWF:URLRequest=new URLRequest("CMO.swf");
      loader.load(defaultSWF);
      loader.x=Xpos;
      loader.y=Ypos;
      addChild(loader);
      My problem however, is that before when I was using a UILoader component, I had some dynamic text and a little animation running while the clip loaded and I need to rescript it to work without the UILoader component.  The AS I had for that was worked into the UILoader instance name:
      loadFile();
      loadAnimation.stop();
      function loadFile():void {
      CMOLoader.load(new URLRequest("CMO.swf"));
      CMOLoader.addEventListener(ProgressEvent.PROGRESS, progressHandler);
      CMOLoader.addEventListener(Event.COMPLETE, completeHandler);
      function progressHandler(e:ProgressEvent):void {
      prog_txt.visible=true;
      var percent:int=CMOLoader.percentLoaded;
      prog_txt.text=percent+"%";
      function completeHandler(event:Event):void {
      currentFrame+1;
      prog_txt.visible=false;
      loadAnimation.visible=false;
      CMOLoader.removeEventListener(ProgressEvent.PROGRESS, progressHandler);
      CMOLoader.removeEventListener(Event.COMPLETE, completeHandler);
      So now I'm trying to figure out how to extract and rescript the animation (loadAnimation) and the text (prog_txt) to fit my new AS that loads the file now.
      Thank you for any ideas!
