0 Replies Latest reply on Jun 25, 2009 2:28 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 8258: Fix bug http://bugs.adobe.com/jira/browse/ SDK-21665 FXG compiler should honor Graphic node attributes viewWidth and viewHeight
    Evtim Georgiev (Adobe) Level 2
      Revision: 8258
      Author:   egeorgie@adobe.com
      Date:     2009-06-25 14:06:28 -0700 (Thu, 25 Jun 2009)
      Log Message:
      Fix bug http://bugs.adobe.com/jira/browse/SDK-21665 FXG compiler should honor Graphic node attributes viewWidth and viewHeight
      Fix: - Added protected viewWidth and viewHeight properties to SpriteVisualElement
      - Modified compiler to generate code to initialize those props in the c-tor of the SirpteVisualElement subclass
      - Modified SpriteVisualElement to mimic the behavior of the tag width/height properties (setting those directly in the mxml on the FXG tag used to squish the visuals, now the visuals are not distorted anymore).
      - Trimmed some code from the SpriteVisualElement taking into account that its min and max match its preferred size.
      Doc Notes: None
      Bugs: SDK-21665
      Reviewer: Pete, Jason
      tests: checkintests
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
