17 Replies Latest reply on Jul 13, 2009 5:45 PM by -==cfSearching==-
    CFPDF - adding watermark image with a transparent background (png or gif)
    mjp420
      I'm have trouble getting an added watermark with a transparent background to display properly when adding it to a pdf using <cfpdf>.  My code below:
      <cfpdf
          action = "addwatermark"
          source = "sample_ddx.pdf"
          image = "starburst.png"
          foreground = "yes"
          isBase64 = "yes"
          overwrite = "yes"
          pages = "1"
          showonprint = "yes"
          position = "0,0"
          opacity = "10"
          destination = "sample_ddx_startburst.pdf"
      I've tried changing isBase64, foreground, etc and it always changes the transparent part of the gif or png to white.  Has anybody ever been able to get this to work?  I haven't been able to find anthing in the doc's that say it isn't supported...
      Thanks for any info anyone might have....
      -Michael
        • 1. Re: CFPDF - adding watermark image with a transparent background (png or gif)
          Dileep_NR Level 2
          Please try this,
          <cfpdf
                  action="addwatermark"
                  source="sample_ddx.pdf"
                  image="./test.jpg"
                  destination="#expandpath("newpdf")#/watermarkforeground.pdf"
                  overwrite="yes"
                  pages ="1,3,6-8"
                  rotation="45"
          • 2. Re: CFPDF - adding watermark image with a transparent background (png or gif)
            -==cfSearching==- Level 4
            I ran a few tests and did not have much luck with transparent images either.  If you cannot get it to work with cfpdf, you might consider trying to add the watermark with iText (used the hood for cfdocument).  See if it makes a difference.
            <cfpdf
                opacity = "10"
            I assume you just testing different settings, as "10" means totally opaque.
            • 3. Re: CFPDF - adding watermark image with a transparent background (png or gif)
              catchme_dileep wrote:
              Please try this,
              What is the difference between that and the original code?
              • 4. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                mjp420 Level 1
                @catchme_dileep:
                Not sure what the difference is in your code as opposed to what it have.
                @cfSearching:
                Unfortunately i'm on a shared server so i can't do any tinkering by adding JAVA libraries -- so i assume that iText is out of the question.
                And yes, i understand i set the opacity to 10 - tried lots of values for this but no difference in whether the watermark image keeps it's transparency or not.  I'm definitely not a expert to the underworkings of gif's and png's -- maybe they need to be built with a transparency in a certain way in order for it to work?!? ( alpha transparency as opposed to index transparency)  I did try that using Fireworks to create the watermark images but i really don't know the underliying difference's between the two are.
                • 5. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                  ColdFusion uses iText for cfdocument. So you do not need to add jars. It is already built in. But you do need access to createObject(..).  So that might eliminate this option for you.You might also try using ddx with <Watermark> to see if the results are any different.
                  • 6. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                    mjp420 Level 1
                    Thanks for the info...i'll look into iText then.  As for the ddx, i am actually adding text as a watermark using ddx right before my cfpdf tag. Basically, i'm adding two separate watermarks to a pdf (one is a bunch of text that i add via ddx). The other is an image that i'm attempting to add via cfpdf.  I didn't see an example of addng an image watermark via ddx -- i only saw examples of text.  Would i just at an <img> tag in the ddx file like so:
                    <DDX xmlns="http://ns.adobe.com/DDX/1.0/"
                        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                        xsi:schemaLocation="http://ns.adobe.com/DDX/1.0/ coldfusion_ddx.xsd">
                        <PDF result="DestinationFile">
                            <PDF source="SourceFile">
                                <Watermark rotation="0" opacity="100%" horizontalAnchor="#horzAnchor#" horizontalOffset="#horzOffset#" verticalAnchor="#vertAnchor#" verticalOffset="#vertOffset#">
                                    <StyledText>
                                            <img src="pathTowatermark.png" >
                                    </StyledText>
                                </Watermark>
                            </PDF>
                        </PDF>
                    </DDX>
                    • 7. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                      No, I believe the two options for ddx <Watermark> are <StyledText> and <Pdf Source="somePDFFile.pdf">.  So the image would need to be placed inside a pdf file.   Though given that CF does not support all of the ddx features I do not know if two watermarks will be allowed:
                              http://livedocs.adobe.com/livecycle/8.2/ddxRef/001162.html#1557141
                      • 8. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                        mjp420 Level 1
                        Actually, i am able to add both watermarks.  One via ddx and one via cfpdf.  See the attached pdf that was created this way.  The 3 lines of text in the blue area in the upper right was were added with ddx.  The "new" logo in the lower left hand area was added to that pdf with cfpdf.
                        If i could only get that added logo to allow transparency i'd be set...
                        Thanks...
                        • 9. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                          Thanks...
                          No, what I meant was I did not know if you could do both _with ddx_.  I do not know one way or the other.  Just that the livecycle documentation suggested it might be an issue.
                          I have had zero luck with transparency in my tests of cfpdf/ddx. The only thing that worked for me was iText.  If you are allowed to use createObject(...) try the attached.  I tested it with the pdf you posted and it definitely works on CF8.
                              Adaptation of iText examples:
                          <cfscript>
                              savedErrorMessage = "";
                              fullPathToInputFile = ExpandPath("sample_ddx_startburst-1.pdf");
                              fullPathToWatermark = "c:\myTransparentPng.png";
                              fullPathToOutputFile =  ExpandPath("startburstWatermarked.pdf");
                              try {
                                  // create PdfReader instance to read in source pdf
                                  pdfReader = createObject("java", "com.lowagie.text.pdf.PdfReader").init(fullPathToInputFile);
                                  totalPages = pdfReader.getNumberOfPages();
                                  // create PdfStamper instance to create new watermarked file
                                  outStream = createObject("java", "java.io.FileOutputStream").init(fullPathToOutputFile);
                                  pdfStamper = createObject("java", "com.lowagie.text.pdf.PdfStamper").init(pdfReader, outStream);
                                  // Read in the watermark image
                                  img = createObject("java", "com.lowagie.text.Image").getInstance(fullPathToWatermark);
                                  // adding content to each page
                                  i = 0;
                                  while (i LT totalPages) {
                                      i = i + 1;
                                      content = pdfStamper.getOverContent( javacast("int", i) );
                                      img.setAbsolutePosition(0, 0);
                                      content.addImage(img);
                                      WriteOutput("Watermarked page "& i &"<br>");
                                  WriteOutput("Finished!");
                              catch (java.lang.Exception e) {
                                  savedErrorMessage = e;
                              // closing PdfStamper will generate the new PDF file
                              if (IsDefined("pdfStamper")) {
                                  pdfStamper.close();
                              if (IsDefined("outStream")) {
                                  outStream.close();
                          </cfscript>
                          <!--- show any errors --->
                          <cfif len(savedErrorMessage) gt 0>
                              ERROR - Unable to create document
                              <cfdump var="#savedErrorMessage#">
                          </cfif>
                          • 10. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                            mjp420 Level 1
                            Dude!  That worked!!!  Mucho thanks!  It definitely take a lot longer to run that page (not exactly sure but was approx 10+ seconds for it to return but i think that'll work.
                            Thanks again for your help!
                            -Michael
                            • 11. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                              I am surprised about a time increase.  I ran it with the file you posted and it was pretty quick, as the input file is not that large.  But in any event, I am glad it works for you.
                              Cheers
                              • 12. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                                BTW, Did you submit a bug report on this?  It is either a bug in the behavior or documentation.
                                • 13. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                                  CF_Ali
                                  Hi Mike,
                                  This might help you out, because im not sure where would you get your image, whether its uploaded, or its already on the server. But I will asume that you already have the photo.
                                  Use the cfimage tag to write the photo in an empty photo variable in which you would just simply upload as it is with your file. Now, you can first read the image using cfimage into a variable then resize it, or manipulated using image() methods, finally read it with cfimage again and write it into a variable.
                                  example:
                                  <cfimage action="read" yada yada>
                                  now that we have read the image as object
                                  lets resize it:
                                  <cfset ImageSetAnitialising(myImage, "on")>
                                  <cfset ImageScaleToFit(myImage, 45, 45>
                                  <cfif myImage.width GTE myImage.height>
                                  <cfset x = 0>
                                  <cfset y = ceiling((myImage.width - myImage.height)/2>
                                  <cfelse>
                                  <cfset x = ceiling((myImage.height - myImage.width) / 2>
                                  </cfif>
                                  <!-- below we will reset the images size AND BORDER so make sure that if you want to
                                  have another color than WHITE to specify it -->
                                  <cfset newimg = ImageNew("", 45, 45, "rgb", "FFFFFF")>
                                  <cfset ImagePaste(newimg, myImage, x, y)>
                                  <!-- here is where we write the image to the place holder image that we have which is pro#Number#>
                                  <cfimage source="#newimg#" action="write" destination="images/Pro#randNum#.jpeg" overwrite="yes">
                                  I hope that helps
                                  Please let me know how that went for ya
                                  • 14. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                                    CF_Ali wrote:
                                    Umm.. how does that help with the watermarking and transparency issues?
                                    • 15. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                                      mjp420 Level 1
                                      @cfSearching
                                      I didn't before but after your suggestion i did submit a bug report with Adobe.  Hopefully we'll see that fixed -- or at least some updated documentation.
                                      On another note, does the "remember me" option when logging into this forum actually do anything?   Every time i come back to this thread to look at it i have to log back in.   And i mean after a couple of hours or so...but i'd think that the "remember me" function would set a cookie that would actually REMEMBER ME  :-)
                                      • 16. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                                        I do not know.  I am just happy when the login option works.  It seemed to malfunction a few posts back and now I cannot even go back and correct my awful typing as there is no "Edit" option on those posts ;-)
                                        • 17. Re: CFPDF - adding watermark image with a transparent background (png or gif)
                                          mjp420,
                                          BTW, this issue appears to be fixed in the CF9 beta.
                                          -Leigh
