1. Re: Work on animated skin
Full Throttle1 Jul 17, 2009 3:52 AM (in response to rudo_fr)You cannot change the SWF unless you have Flash project file (.FLA) with you. Otherwise you will have to rewrite the complete SWF code that plays FlashDVD.
2. Re: Work on animated skin
mrpeterk1 Oct 3, 2009 10:55 AM (in response to Full Throttle1)Hi,
Can you elaborate on what you meant. I have a FlashDVD.swf I made with Enocre CS4 and I want to somehow change the default Encore player to include a scroll bar. I have Flash CS4 and I'm making a flash website for myself. I tried importing the FlashDVD.swf with no success. All I would like is to have a scroll bar added to the player...
Thanks inadvance for the help,
Peter
3. Re: Work on animated skin
Bill Hunt Oct 3, 2009 4:30 PM (in response to rudo_fr)There was a fairly recent post on the same topic. I think it was just before the sub-fora were rolled into one, and was probably then in the Flash sub-forum.
I do not recall the resolution, but there was discussion. I also do not recall the folk, who replied. I'd do a Search of this forum for "skin" and it will likely pop up. Perhaps there are more, but I do not recall those.
Also, maybe Full Throttle can solve your need, and then this will be the definitive post on the subject.
4. Re: Work on animated skin
Full Throttle1 Oct 15, 2009 7:08 AM (in response to Bill Hunt)You cannot change the SWF file in Encore. SWF file is created using a Flash project (.FLA) which is not available for users. Only option is to write a Flash project and generate a new SWF which may not be worth the effort.
5. Re: Work on animated skin
Mylenium Oct 15, 2009 11:39 AM (in response to mrpeterk1)You would have to decompile the Flash file (which may be against the license agreement) into an editable FLA and then make sense of the code. I doubt that this would be very sensible. Unless Adobe themselves provide the template, there is no way to change any of that. Of course you still could write your own player from scratch. After all the XML is human readable and the actual clips are just standard FLV files...
Mylenium
6. Re: Work on animated skin
mrpeterk1 Oct 15, 2009 5:58 PM (in response to rudo_fr)Thanks for all the info guys..
