1 Reply Latest reply on Jun 30, 2009 6:30 AM by Cr99
    BlazeDS with AIR and messaging
    Cr99 Level 1
      In a recent post:
      http://forums.adobe.com/thread/450648?tstart=0
      I asked about setting up AIR with blazeDS.  Using the link from the previous post, I got it working for remoting ok:
      <mx:RemoteObject id="reportRetrieval" destination="reportLoad" channelSet="{amfChannelSet}">
      But I can't get it working for messaging.  How do I define destinations (not channels) for AIR at runtime?  In Flex, I just define them in the messaging-config.xml file.  For remoting I define a channel, but for messaging I define a destination.  Here's what I have from the messaging-config file which works in flex:
      <?xml version="1.0" encoding="UTF-8"?>
      <service id="message-service"
          class="flex.messaging.services.MessageService">
           <adapters>
              <adapter-definition id="TCautomation" class="factory.AutoWatcher"/>
              <adapter-definition id="actionscript" class="flex.messaging.services.messaging.adapters.ActionScriptAdapter" default="true" />
          </adapters>
          <default-channels>
              <channel ref="my-polling-amf"/>
          </default-channels>
           <destination id="autoWatch">
               <adapter ref="TCautomation"/>
           </destination>
      </service>
      And here are my components in mxml:
      <mx:Producer id="reportManager" destination="autoWatch"/>
      <mx:Consumer id="consumer" destination="autoWatch" message="messageHandler(event.message)"/>
        • 1. Re: BlazeDS with AIR and messaging
          Cr99 Level 1
          Ok, well I've made some progress.  I can now send messages, but I can't receive them.
          Here's how I set it up in actionscript:
          private var producer:Producer = new Producer();
          private var consumer:Consumer = new Consumer();
          private var blazeUrl:String = "http://localhost:8888/myApp/messagebroker/";
          public function init():void {
          var myPollingAMF:AMFChannel = new AMFChannel("my-polling-amf", blazeUrl + "amfpolling");
          myPollingAMF.pollingEnabled = true;
          var channelSet:ChannelSet = new ChannelSet();
          channelSet.addChannel(myPollingAMF);
          consumer.channelSet = channelSet;
          producer.channelSet = channelSet;
          consumer.destination = "autoWatch";
          producer.destination = "autoWatch";
          consumer.addEventListener(MessageEvent.MESSAGE, messageHandler);
          consumer.subscribe();
          var message:IMessage = new AsyncMessage();
          message.body.command = "message received ???";
          producer.send(message);
          // alert never gets fired due to error
          private function messageHandler(message:IMessage):void {
          Alert.show(" MESSAGE delivered");
          And here is the invoke method in my Java:
          public Object invoke(Message message) {
          MessageService  service = (MessageService)getDestination().getService();
          String clientID = UUIDUtils.createUUID();
          Message message = new AsyncMessage();
          message.setDestination("autoWatch");
          message.setClientId(clientID);
          message.setMessageId(UUIDUtils.createUUID());
          message.setTimestamp(System.currentTimeMillis());
          TreeMap <String, String>hMap = new TreeMap<String, String>();
          hMap.put("reportID", "rep1");
          message.setHeaders(hMap);
          message.setBody("msg");
            // the following prints and I turn around and try to communicate
            // with consumer (see actionscript above)
            System.out.println("Messge successfully received");
             try {
                  service.pushMessageToClients(message, false); // fails
             catch (Exception e) {
                 System.out.println("\t PROBLEM SENDING");
                  e.printStackTrace();
          return "success";
          And here is the error I get on the AIR debug side:
          TypeError: Error #1034: Type Coercion failed: cannot convert mx.messaging.events::MessageEvent@1307ad29 to mx.messaging.messages.IMessage.
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.messaging::AbstractConsumer/http://www.adobe.com/2006/flex/mx/internal::messageHandler()[E:\dev\3.0.x\frameworks\proje cts\rpc\src\mx\messaging\AbstractConsumer.as:711]
          at mx.messaging::ConsumerMessageDispatcher/messageHandler()[E:\dev\3.0.x\frameworks\projects \rpc\src\mx\messaging\ConsumerMessageDispatcher.as:251]
          at mx.messaging::ChannelSet/messageHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\mes saging\ChannelSet.as:1285]
          at PollCommandMessageResponder/resultHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\m essaging\channels\PollingChannel.as:739]
          at mx.messaging::MessageResponder/result()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\messa ging\MessageResponder.as:199]
          Could someone please tell me what I'm doing wrong?  Thanks.
