0 Replies Latest reply on Jun 26, 2009 8:05 AM by Paul Reilly
    [svn:fx-trunk] 8306: * A trio of compiler fixes.
    Paul Reilly Level 1
      Revision: 8306
      Author:   preilly@adobe.com
      Date:     2009-06-26 08:05:34 -0700 (Fri, 26 Jun 2009)
      Log Message:
      • A trio of compiler fixes.
      tests Passed: checkintests
      Needs QA: YES, please confirm each of the bug fixes with AST
                generation on and off.
      Needs DOC: NO
      Bug fixes: SDK-20158, SDK-21871 with AST generation, SDK-21528
      API Change: NO
      Reviewer: Pete F.
      Cycloner: Gaurav
      Code-level description of changes:
        as3/AbstractSyntaxTreeUtil.java
          Modified generateMemberExpression() to handle expressions like Vector..
        as3/binding/DataBindingFirstPassEvaluator.java
          Renamed isString() to isArrayOrString() and added check for Array.
        mxml/lang/StandardDefs.java
          Added intern() to PACKAGE_FLASH_UTILS, because it's used in AST
          generation now.
        mxml/lang/ChildNodeHandler.java
          Modified invoke() to call defaultPropertyElement() even in the
          case of binding expressions.
        mxml/builder/ComponentBuilder.java
          Modified constructor to initialize bindingHandler.
          Added ComponentDeclarationBindingHandler inner class.
        mxml/builder/DocumentBuilder.java
          Removed ComponentDeclarationBindingHandler inner class.
        mxml/rep/init/ValueInitializer.java
          Modified formatExpr() to handle fully qualified class names when
          the targetType is functionType.
        mxml/gen/ClassDefLib.vm
          Added special case handling, equivalent to compile time singleton
          coercion, for binding source functions when the return type is
          Array.
        mxml/ImplementationGenerator.java
          AST generation equivalent to ClassDefLib.vm changes.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-20158
          http://bugs.adobe.com/jira/browse/SDK-21871
          http://bugs.adobe.com/jira/browse/SDK-21528
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/TypeAnalyzer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/ChildNodeHandler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
