This content has been marked as final.
Show 18 replies
1. Re: What's the simplest way of getting my web-site in the middle
Ben M Aug 5, 2008 7:50 AM (in response to virtutour)Don't use absolute positioning. If you want your layout to appear in the center of the screen you can do the following:
<div id="container">
<div="content"></div>
</div>
Then your CSS would look like:
#container {
margin: 0 auto; /* This will do top of the page and center align*/
The content wouldn't really need any positioning since it is inside the container. Unfortunately, there is no way to center the design height-wise on the screen using CSS like this. I hope this is what you were looking for. -
2. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 5, 2008 8:00 AM (in response to virtutour)Wrong. You need to give the div#container a width for auto margins to have
any effect - otherwise it will fill the width of the container, giving you
auto margins of zero on left/right.
#container { width:760px; margin:0 auto; }
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"SnakEyez02" <webforumsuser@macromedia.com> wrote in message
news:g79pbm$mn9$1@forums.macromedia.com...
> </div>
> #container {
> height-wise on
3. Re: What's the simplest way of getting my web-site in the middle
virtutour Aug 8, 2008 6:30 AM (in response to virtutour)Thanks chaps
Please bear with me as I do not usually do direct coding but just use dreamweaver 3.0's wysywig editor.
I have tried creating a css style sheet using notepad and renaming it to .css with the content:
But then when I import the sytle sheet dreamweaver doesn't see it?
Don't style sheets have to start with a full stop
Very confused
Masten -
4. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 8, 2008 7:18 AM (in response to virtutour)On Fri, 8 Aug 2008 13:30:49 +0000 (UTC), "virtutour"
No - just a normal file name - usually like this main.css
you are thinking of classes which do start with a full stop inside the
style sheet
~Malcolm~*...
5. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 8, 2008 7:32 AM (in response to virtutour)> Please bear with me as I do not usually do direct coding but just use
Be prepared for a long and tedious learning curve, then.
Let's see your code, please.
"virtutour" <webforumsuser@macromedia.com> wrote in message
news:g7hhq9$isj$1@forums.macromedia.com...
> Thanks chaps
> .css
> with the content:
> Very confused
> Masten
6. What's the simplest way of getting my web-site in the middle
virtutour Aug 8, 2008 12:37 PM (in response to virtutour)Hi Malcom
"you are thinking of classes which do start with a full stop inside the
style sheet"
what I dont get is where
goes? In the css file? But dreamweaver wont read it?
'Be prepared for a long and tedious learning curve, then'
No problem, but the site will be very simple. Just a container for my work really.
Can I take this a step at a time. Please see code below which just has the main image in it. Id like to start off with just getting this centered hoiizontally.
7. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 8, 2008 1:01 PM (in response to virtutour)No code below, as you see below.
This -
goes in your stylesheet (either linked or embedded on the page).
It will style a page element with id="container".
DW reads it beautifully.
news:g7i79f$bvb$1@forums.macromedia.com...
> Hi Malcom
> style sheet"
> goes? In the css file? But dreamweaver wont read it.
> really.
> main image in it.
8. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 8, 2008 1:10 PM (in response to virtutour)On Fri, 8 Aug 2008 19:37:19 +0000 (UTC), "virtutour"
>Hi Malcom
> style sheet"
classes - which can be used as many times as you want on a page.
in the style sheet they look like this
.aclass { ..... }
an id which can only be used ONCE in a page
in the style sheet they look lile this
#anID { ....}
note that an ID has a higher significant - and scores higer in
"specificity" - so an ID with the same name as a class will overrule a
class of the same name.
~Malcolm~*...
9. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 8, 2008 1:29 PM (in response to virtutour)> note that an ID has a higher significant - and scores higer in
Having an ID and a class with the same name sounds like confusion to me.
Better to say that if both an ID and a class apply to the same element, the
ID's rule will override any conflicting styles from the class, e.g.,
#this { color:red; }
.that { color:blue; }
<p id="this" class="that">This text is red.</p>
"Malcolm _" <malcom@mon.org> wrote in message
news:5q9p94tbktb6jan0t6q897b80urmoo0g3h@4ax.com...
>>Hi Malcom
>> style sheet"
> .aclass { ..... }
> #anID { ....}
> ~Malcolm~*...
10. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 8, 2008 1:54 PM (in response to virtutour)On Fri, 8 Aug 2008 16:29:17 -0400, "Murray *ACE*"
I agree - and always try not to use the same name for id's as I do for
classes.
~Malcolm~*...
11. What's the simplest way of getting my web-site in the middle
virtutour Aug 8, 2008 5:15 PM (in response to Newsgroup_User)OK. Kind of got this to work in netscape 7..Doesnt work in IE6? It's also not in the middle but over to one side. -
12. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 8, 2008 7:23 PM (in response to Newsgroup_User).oO(virtutour)
>OK. Got this to work in netscape 7.. Doesnt work in IE6?
The DOCTYPE is missing, which will kick IE and most other browsers into
quirks mode.
> <body bgcolor="00053F">
Use CSS for background colors.
Micha -
13. Re: What's the simplest way of getting my web-site in the middle
virtutour Aug 9, 2008 2:45 AM (in response to virtutour)Hi Michaal
Sorry havent got a clue what DOCTYPE is, and where does it go in the code?
Masten -
14. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 9, 2008 3:11 AM (in response to virtutour)On Sat, 9 Aug 2008 09:45:24 +0000 (UTC), "virtutour"
>Hi Michaal
>Thanks
>Masten
As Murry said " Be prepared for a long and tedious learning curve,
then." :-)
I would throughly recommend that before you do any more you beg,
borrow or otherswise aquire a copy of this book.
HTML,XHTML & CSS by Elizabeth Castro
very comprehensive, readable and attractive book explains all - ( or
most at least )
http://www.cookwood.com/html6ed/contents/index.html
But OK - what is a DOCTYPE - well if you create a website from scratch
it would bt default set up a page with a complete DOCTYPE.
Dw8 and Dw CS3 set up a default XHTML 1.0 Transitional doctype like
this.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
" http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns=" http://www.w3.org/1999/xhtml">
<head>
so it would seem the websites you have aquired cam from another html
editor - or were produced in a nonstandard way.
It is recommended that all websites have a doctype - as this amongst
other things ensures the browsers render the page in the way that you
would expect.
But no matter - Dw can convert an existing page to give you a DOCTYPE
and convert all code to the correct format.
Just use File | Convert - and select the type yopu want. Most of us
here would seem to use XHTML 1.0 - but beware some people still
believe we should use HTML 4 - :-)
Doctypes are described here.
http://en.wikipedia.org/wiki/Doctype
~Malcolm~*...
15. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 9, 2008 3:14 AM (in response to virtutour)On Sat, 9 Aug 2008 09:45:24 +0000 (UTC), "virtutour"
>Hi Michaal
>Thanks
>Masten
sorry meant to add this link as well:
http://www.w3.org/QA/2002/04/valid-dtd-list.html
~Malcolm~*...
16. Re: What's the simplest way of getting my web-site in the middle
virtutour Aug 9, 2008 8:03 AM (in response to Newsgroup_User)Hi Malcom
It works! Thanks for that.
Well, getting elements centered anyway.
How do I now get the java applet to sit on top of the image in the box.
Here's what it looks like so far
www.virtutour.com/new_web_site
Masten -
17. Re: What's the simplest way of getting my web-site in the middle
Newsgroup_User Aug 9, 2008 9:06 AM (in response to Newsgroup_User)On Sat, 9 Aug 2008 15:03:32 +0000 (UTC), "virtutour"
>Hi Malcom
> http://www.virtutour.com/new_web_site
> Thanks
You've lost me now !!!
~Malcolm~*...
18. Re: What's the simplest way of getting my web-site in the middle
virtutour Aug 9, 2008 11:35 AM (in response to virtutour)Dont know how else to explain it.
How do you get the applet on top of the graphic rather than it being underneath. Ive got a feeling, though, this is impossible using css, and I have to use centered tables and cut the graphic up and place it around tha applet.
Its funny, from a non-coders perspective, you would've thought that the seemingly simple desire to just centre a web-site would be an easy thing. How wrong could I have been!
