1 Reply Latest reply on Jun 26, 2009 10:53 AM by ConsistencyHobgoblin
    Images from SQL Server in Flex DataGrid via SOAP.
      I have created a Web Service in C# that delivers thumbnails from SQL Server as byte arrays.  It works.  In C# I can create a client that will display the images using the web service.  I am trying to convert the byte array to a bitmap and use that as the source to a datagrid column with an <mx:Image> in the itemRenderer.  I have tryed several different approaches.
      Using the web service and displaying text is straight forward and I have no problem there.  When I try to use the byte array to create bitmap data and use it in a bitmap object as the source for the <mx:Image> the image is blank.  I wonder if this is an encoding or endean issue.  I'm not sure if there is a stream object as in C# that can be used without file I/O.  I can't see how to use the loader as it requires the result be available in a completion event and therefore limits returning it from a function.  Any direction would be appreciated.  Here is my code:
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="requestAllGenre();" width="640" height="480" xmlns:display="flash.display.*">
      <mx:ComboBox id="cboGenre" dataProvider="{colGenres}" labelField="GenreDescription" x="254" y="10" width="140"></mx:ComboBox>
      <mx:Label x="211" y="12" text="Genre:"/>
      <mx:DataGrid x="49.5" y="38" width="541" height="409" id="grdContent" allowMultipleSelection="false" editable="false" enabled="true" resizableColumns="true" showHeaders="true" sortableColumns="false" wordWrap="true" dataProvider="{colContents}">
      <mx:columns>
           <mx:DataGridColumn headerText="Thumbnail" dataField="ThumbnailByteArray">
                <mx:itemRenderer>
                     <mx:Component id="disp" >
                          <mx:HBox horizontalAlign="center">
                               <mx:Image id="img" source="{outerDocument.byteArrayToBitmap(data.ThumbnailByteArray)}" >
                               </mx:Image>
                          </mx:HBox>
                     </mx:Component>
                </mx:itemRenderer>
           </mx:DataGridColumn>
           <mx:DataGridColumn headerText="Title" dataField="ContentName">
           <mx:DataGridColumn headerText="Description" dataField="ContentDescription">
      </mx:columns>
      </mx:DataGrid>
      <mx:WebService id="ContentServ" showBusyCursor="true"wsdl="http://localhost:3628/ContentManWebService/ContentServ.asmx?wsdl" >
           <mx:operation name="GetAllGenre" resultFormat="object" result="genreResult(event)" >
           </mx:operation>
           <mx:operation name="GetAllContent" resultFormat="object" result="contentResult(event)" >
           </mx:operation>
      </mx:WebService>
      <mx:Script>
      <![CDATA[
      import mx.effects.Pause;
      import mx.utils.Base64Encoder;
      import mx.utils.Base64Decoder;
      import mx.core.Application;
      import mx.collections.ArrayCollection;
      import mx.controls.Alert;
      import mx.rpc.events.ResultEvent;
      import mx.graphics.codec.JPEGEncoder;
      import mx.events.FlexEvent;
      import flash.display.Bitmap;
      import flash.display.BitmapData;
      import flash.display.DisplayObject;
      import flash.display.Graphics;
      import flash.display.Sprite;
      import flash.events.Event;
      Bindable]
      private var colGenres:ArrayCollection;
      Bindable]
      private var colContents:ArrayCollection;
      private var bmpThumbnail:Bitmap;
      private var bImageRendered:Boolean;
      private var nWhileCount:int = 0;
      public function byteArrayToBitmap(ba:ByteArray):Bitmap {
           var bdatThumb:BitmapData = new BitmapData(75, 95, false);
           ba.position = 0;
           bdatThumb.setPixels(
      new Rectangle(75, 95),ba);
           var bmpThumbnailLocal:Bitmap = new Bitmap(bdatThumb);
           return bmpThumbnailLocal
      private function requestAllGenre():void{
           ContentServ.GetAllGenre.send();
      private function requestAllContent():void{
           ContentServ.GetAllContent.send();
      // Gets called when the XML is successfully loaded.
      private function genreResult(event:ResultEvent):void{
           colGenres = event.result
      as ArrayCollection;
           cboGenre.selectedIndex = 0;
      private function contentResult(event:ResultEvent):void{
           colContents = event.result
      as ArrayCollection;
      private function btnSearch_OnClick(event:Event):void{
           requestAllContent();
      </mx:Script>
      <mx:Button x="402" y="10" label="Search" id="btnSearch" click="btnSearch_OnClick(event)" toolTip="Click to Find Matching Content"/>
