0 Replies Latest reply on Jun 26, 2009 11:35 AM by Darrell Loverin
    [svn:fx-trunk] 8320: Fix the problem where the WindowedApplication was not shutting down after closing Windows .
    Darrell Loverin Level 4
      Revision: 8320
      Author:   dloverin@adobe.com
      Date:     2009-06-26 11:34:59 -0700 (Fri, 26 Jun 2009)
      Log Message:
      Fix the problem where the WindowedApplication was not shutting down after closing Windows.
      The problem ended up being the Window class was creating a new NativeWindow (and WindowedSystemManager) in commitProperties() before closing down. The problem is easily fixed by setting flagForOpen to false so the code will not come down this path after _nativeWindow is set to null in the close() method.
      QE Notes: none.
      Doc Notes: none.
      Bugs: SDK-21529
      Reviewer: Glenn
      tests: checkintests
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21529
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/Window.as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/Window.as
