2 Replies Latest reply on Jul 6, 2009 10:49 AM by Jerry62712
    XML processing
    Jerry62712 Level 1
      I was able to get the input stream from the queryString to the application I'm working with.  For example, if you called the application with this:
      FSCalc.html?xml=<?xml version="1.0" encoding="UTF-8" ?><FSParm><HouseholdSize>6</HouseholdSize><GrossMonthlyEarnedIncome>2000</GrossMonthlyEar nedIncome>
      </FSParm>
      the contents of the string of the input is this:
      inputString=<?xml version="1.0" encoding="UTF-8" ?><FSParm><HouseholdSize>6</HouseholdSize><GrossMonthlyEarnedIncome>2000</GrossMonthlyEar nedIncome></FSParm>
      I then take that string and put it in an XMLList.
      private var parseXML:XMLList = inputString;
      What I need to know now is how to get the key name and value pairs in an actionscript.  In pseudo code it would look like this:
                 for each(item in parseXML) {
                    if (item key = "xyz") {
                       setXYZ(item value) }
                    if (item key = "abc" {
                       setABC(item value) }
      How can I make this happen?
        • 1. Re: XML processing
          Flex harUI Adobe Employee
          I don't trust auto-conversion in AS3 (it works reliably, I just cannot remember the rules).
          So, I think you started with a string that was the full url, and found a way to find a substring that was the right hand side of xml=.
          If inputString a string, that should be converted to XML (not XMLList) via
          Var fsParm:XML = new XML(inputString);
          And its pieces will then be available as:
          fsParm.HouseholdSize
          fsParm.GrossMontlyEarnedIncome
          fsParm.HouseholdSize is an XMLList so to get a number you have to do
          var householdSize:int = int(fsParm.HouseholdSize[0].toString())
          or if you know there'll only be one entry in the list,
          var householdSize:int = int(fsParm.HouseholdSize.toString())
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: XML processing
            Jerry62712 Level 1
            Thank you.  I have another problem that I'll start a new thead with (to not pollute this one).
