0 Replies Latest reply on Jun 26, 2009 5:22 PM by Jason Szeto
    [svn:fx-trunk] 8344: Rect radius bug fix
    Jason Szeto Level 3
      Revision: 8344
      Author:   jszeto@adobe.com
      Date:     2009-06-26 16:58:50 -0700 (Fri, 26 Jun 2009)
      Log Message:
      Rect radius bug fix
      http://bugs.adobe.com/jira/browse/SDK-21867 -   Rect with only radiusX properly set does not render properly
      Fixed Rect?\226?\128?\153s handling of radiusX and radiusY to match the spec.
      ?\226?\128?\156If a properly specified value is provided for radiusX but not for radiusY, then the user agent processes the Rect element with the effective value for radiusY as equal to radiusX. If radiusX is not specified, or is specified as zero, then the user agent processes the Rect element as if no rounding had been specified, resulting in square corners.?\226?\128?\157
      QE Notes: Update tests
      Doc Notes: Update docs to mention this new behavior
      Bugs: SDK-21867
      Reviewer: Awaiting review
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Rect.as
