1 Reply Latest reply on Jun 29, 2009 11:52 PM by dam.C
    Help me to find Memory Leak
    dam.C
      Hi All,
            I have  very basic application which uses  DataSerives over RTMP channel  to populate dataGrid , I have not used any  user defined component.
      This application has got LOAD data and Remove data  Button just to simulate the actual application
      What happens , when I click on LOAD data , It  loads the data from server(JBOSS) then I Remove all the data and force the GC to run
      If I continuously keep loading and removing the  data ,  memory goes up every time and after some times It reaches to threshold and  finally crashes the Browser.
      In actual application as soon as user logs in a dedicated DS destination is created..
          private function createDestination(destName:String):void{
                   var remoteService:RemoteObject = new RemoteObject("DestinationManager");
                   remoteService.addEventListener(ResultEvent.RESULT, resultHandler,false,0,true);
                   var operation:AbstractOperation = remoteService.getOperation("createDestination");
                   operation.send(destName);
                   var cs:ChannelSet = new ChannelSet();
                   var rtmpChannel:RTMPChannel = ServerConfig.getChannel("my-rtmp") as  RTMPChannel;
                   cs.addChannel(rtmpChannel);
                   tradeService = new DataService() ;
                   tradeService.destination=destName;
                   tradeService.channelSet = cs;
      Now when user hits on Load data button to load the trade data ...
         public function loadData():void
               var remoteService:RemoteObject  = new RemoteObject("filterRemoteVO");
               var operation:AbstractOperation = remoteService.getOperation("loadData");
               tradeService.fill(tradeCollection);
               operation.send(rowData.text ,GUIID);
               tradeList.dataProvider = tradeCollection;
      Remove Data  hit I clean all the resource and released collection :-
            public  function  removeAll():void{
               if(tradeList.dataProvider){
                    tradeCollection.source = new Array();
                    tradeList.dataProvider.source = new Array();
                    tradeList.dataProvider = null;
                  tradeService.release();
                 tradeService.releaseCollection(tradeCollection);
                tradeService.channelSet.disconnectAll();
                tradeService.disconnect();
                 tradeService.logout();
                 System.gc();
      Except these 3 function I don't have any code which could cause memory leak.
      I m using
      • LCDS 2.5
      • Flex 3.0
      • JBoss4.2
      Please see the mxml file below   , If  possible please have a look at it , I might  not be using dataSerice API correctly.
      I have been trying to solve this leak for last two week , I really need help from you guys.
      My client has already evaluating other contemporary technology because of this memory issue.
      I have also created scalled down war file which can be deployed on any  java application server.
      Any help will greatly be appreciated
      Regards,
      Dam
      ######################## MXML##########################
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
            creationComplete="init();" height="100%" width="100%"
           <mx:Script >
           <![CDATA[
               import mx.containers.GridRow;
                 import mx.utils.Base64Decoder;
               import mx.utils.StringUtil;
                  import mx.events.CollectionEvent;
               import mx.formatters.Formatter;
               import mx.events.ResizeEvent;
               import mx.controls.DataGrid;
               import mx.effects.Fade;
               import mx.events.DataGridEvent;
               import mx.utils.ObjectUtil;
               import mx.events.ScrollEvent;
             import mx.formatters.DateFormatter;
             import mx.events.ListEvent;
             import mx.data.mxml.DataService;
             import mx.messaging.config.ServerConfig;
             import mx.messaging.channels.RTMPChannel;
             import mx.messaging.ChannelSet;
             import mx.rpc.AbstractOperation;
             import mx.rpc.remoting.RemoteObject;
             import mx.collections.ArrayCollection;
             import mx.controls.Alert;
             import mx.rpc.events.ResultEvent;
             import mx.messaging.messages.*;
             import mx.messaging.events.*;
              private var GUIID:String;
              private var lastRollOverIndex:Number;
              public var tradeService:DataService=null;
              public var tradeCollection:ArrayCollection = new ArrayCollection();
             public var flag:Boolean = false;
              private function init():void {
                 var guiId:String ="TEST";
                  createDestination(GUIID);
              public function getData():void{
                   // memory.text =""+ ((System.totalMemory / 1024)/1024);
              public function releaseDataServices():void {
                 //  tradeService.fill(null);
                     // tradeService.releaseCollection(tradeCollection);
                      //tradeService.dataStore = null;
                      /*Function for creating destination*/
               //This function calls dataservice fill method depending on wheather destination is created or not
              private function resultHandler(event:ResultEvent):void{
                 //call data service as destination is created successfully
                  var status:Boolean = event.result as Boolean
                 // Alert.show("status="+status);
                  if(status){
                   getData();
                 else{
                     //TODO report error to MATS app
                 System.gc();
      </mx:Script>
            <mx:DataGrid   id="tradeList"
                   initialize="tradeList.dataProvider = tradeCollection" horizontalScrollPolicy="auto"
                     height="659" x="0" y="84">
                  <mx:columns>
                       <mx:DataGridColumn  headerText="Security Description" dataField="securityDesc"
                       <mx:DataGridColumn  headerText="B/S" dataField="transactionType"
                       <mx:DataGridColumn  headerText="Amount" dataField="amount"
                       <mx:DataGridColumn  headerText="Price Text" dataField="priceText"
                       <mx:DataGridColumn  headerText="Counterparty" dataField="counterParty"
                       <mx:DataGridColumn  headerText="Trade Date" dataField="tradeDate"
                       <mx:DataGridColumn  headerText="Settle Date" dataField="settleDate"
                       <mx:DataGridColumn  headerText="Trade Status" dataField="tradeStatusId"
                       <mx:DataGridColumn  headerText="Trader" dataField="trader"
                       <mx:DataGridColumn  headerText="Salesperson" dataField="salesperson"
                       <mx:DataGridColumn  headerText="Ticket Number" dataField="tradeNumber"
                       <mx:DataGridColumn  headerText="Entry Date" dataField="tradeTime"
                       <mx:DataGridColumn  headerText="Cancel Date" dataField="cancelDate"
                       <mx:DataGridColumn  headerText="Cancel Time" dataField="cancelTime"
                   </mx:columns>
                </mx:DataGrid >
               <mx:Grid x="149" y="23" width="995">
                       <mx:GridRow width="100%" height="100%">
                                  <mx:GridItem width="100%" height="100%">
                                       <mx:Label text="Enter No of obejcts"   width="111"/>
                               </mx:GridItem>
                                       <mx:TextInput name="row" id="rowData"   width="97"/>
                               </mx:GridItem>
                                       <mx:Button  label="Load Data" click='loadData()'/>
                               </mx:GridItem>
                                       <mx:Button  label="removeAll" click='removeAll()'/>
                               </mx:GridItem>
                                       <mx:Label text="Total Memory"/>
                               </mx:GridItem>
                                       <mx:TextInput text="Total Memory" id="memory"   width="97"/>
                               </mx:GridItem>
                                       <mx:Label text="Grid Row Count"/>
                               </mx:GridItem>
                                       <mx:TextInput name="GridRowCountN" id="GridRowCount"   width="97"/>
                               </mx:GridItem>
                       </mx:GridRow>
               </mx:Grid>
      </mx:Application>
