1 Reply Latest reply on Jun 28, 2009 10:43 PM by SunilAdobe
    Paging Parameter
    Rockferd1
      Hi guys,
      Been messing around with Flash Builder 4, loving it .  I have a question, i've used the built in paging for a mass list, but what if I want that functinality for let's say, one team? So my parameter would be a teamid to be passed to the PHP service.  How can I go about making whatever modification needs to be done, or whatever it'd require?
      ~Rock
        • 1. Re: Paging Parameter
          SunilAdobe Adobe Employee
          Great that you are having success building applications with FlashBuilder 4.
          • You can add a parameter to your paging function on the php side
          • Code your php function which uses this parameter to get you a set of records
          • Refresh the service in FB4, you should be able to see the new signature of the paging function
          • Just change your calls in Flex to the paging function to include the team paramter
          That should be it.
          Hope this helps.
          -Sunil
