21 Replies Latest reply on Sep 26, 2008 4:02 AM by Newsgroup_User
    Table size and content issues
    summer_sam2009
      hii..m developin a site using dreamweaver cs3..n m facing a problem in the table contents..i want to use marquee text which moves horizontally..i used the marquee tags and some how managed to do it..nw the problem is the table size has increased as soon as i used the marquee text under it..the size issues are developing which nower i cn find out 2 solve the problem..plz help in dis case..
        • 1. Re: Table size and content issues
          Level 7
          wd nd 2 c da pge. lnk pls
          Walt
          "summer_sam2009" <webforumsuser@macromedia.com> wrote in message
          news:gbf7nh$o9s$1@forums.macromedia.com...
          > used the
          > size
          > are
          > case..
          • 2. Re: Table size and content issues
            summer_sam2009 Level 1
            should i sent u the page by mail...or d coding part..
            • 3. Re: Table size and content issues
              www.itsimpex.com..dis my site which i m creating..in d home page i want d contents in the exice customs n dgft..in dat i want 2 use d marquee text which moves upwards..nw as soon as i entered the text inside d excise d size reagrding excise sumhw increaed leaving a space of sum blks..nw i dnt want size 2 b increased n i want dat in a proper size which i hv alrdy defined..
              • 4. Re: Table size and content issues
                www.itsimpex.com..dis my site which i m creating..in d home page i want d contents in the exice customs n dgft..in dat i want 2 use d marquee text which moves upwards..nw as soon as i entered the text inside d excise d size reagrding excise sumhw increased leaving a space of sum blks..nw i dnt want size 2 b increased n i want dat in a proper size which i hv alrdy defined..
                • 5. Re: Table size and content issues
                  • 6. Re: Table size and content issues
                    Level 7
                    Address Not Found
                    Firefox can't find the server at www.itsimpex.com..dis.
                    Walt
                    news:gbfaar$r58$1@forums.macromedia.com...
                    > which
                    > size
                    • 7. Re: Table size and content issues
                      Level 7
                      http://www.itsimpex.com works.
                      I suspect "..dis" after .com actually starts the next sentence "dis my
                      site..."
                      Regards
                      John Waller
                      • 8. Re: Table size and content issues
                        i m sending d code..plz check in dat d space under custom,excise,dgft.i want 2 use d marquee text under dem but d table width is automtically increasing bcoz i m copyin d content frm other side..jst wants 2 use the notifications part for daily updates..so the width is increasing of customs,excise and dgft.
                        • 9. Re: Table size and content issues
                          Level 7
                          Please - this is not texting. It's writing intelligible english sentences.
                          Can you do that?
                          Murray --- ICQ 71997575
                          Adobe Community Expert
                          (If you *MUST* email me, don't LAUGH when you do so!)
                          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                          news:gbfab9$r5i$1@forums.macromedia.com...
                          > which
                          > want
                          > defined..
                          • 10. Re: Table size and content issues
                            Level 7
                            Walt...You are one funny mofo...
                            Page seemes to be correct from my view.
                            Gary
                            "Walt F. Schaefer" <walt@waltswebworx.com> wrote in message
                            news:gbf91l$pq2$1@forums.macromedia.com...
                            > Walt
                            >> the
                            >> used the
                            >> size
                            >> issues are
                            >> case..
                            • 11. Table size and content issues
                              if u have observed the page very carefully den u mst have noticed that on the customs.jpg which is on right hand side d th width is 168 n on the left side the width th is 133..nw as soon as i change th width 168 to 133..stil der is a liitle space left as u closely observe..thw width of the left and right hand side r nt same..
                              • 12. Re: Table size and content issues
                                Level 7
                                Ok, the funny mofo was directed at walt...hence the sentence "Walt...You are
                                one funny mofo..."
                                Second, I did not look that close, in the 100% view in both IE and FF, I
                                dont see the space. When I enlarge it to 340%, I think I might be seeing a
                                space, where the image is .
                                Since your image and table are 130x22, I suggest you set your cellpad and
                                cellspace in the table to 0.
                                Third, as Murray pointed out, your use of text language makes your post
                                harder to read, thus you are not getting the benefit of smarter people than
                                I to help you out.
                                gary
                                news:gbftua$l4t$1@forums.macromedia.com...
                                > the
                                > side
                                > is a
                                > hand
                                > side r nt same..n if u feel den i m a funny mofo..dat means either u r nt
                                > gettin wat m sayin or u jst being funny..
                                • 13. Re: Table size and content issues
                                  Level 7
                                  Apparently my attempt at sarcasm was lost on the OP. ;-)
                                  Walt
                                  "GPaul" <gwpaul@ptd.net> wrote in message
                                  news:gbfsoi$jok$1@forums.macromedia.com...
                                  > Gary
                                  >> Walt
                                  >>> the
                                  >>> used the
                                  >>> size
                                  >>> issues are
                                  >>> dis case..
                                  • 14. Re: Table size and content issues
                                    Level 7
                                    new dat
                                    Walt
                                    "John Waller" <johnw@REMOVETHISpinnacleweb.com.au> wrote in message
                                    news:gbfdmb$1g3$1@forums.macromedia.com...
                                    > site..."
                                    > Regards
                                    > John Waller
                                    • 15. Re: Table size and content issues
                                      Level 7
                                      oic
                                      news:gbg98o$5bt$1@forums.macromedia.com...
                                      > new dat
                                      > Walt
                                      >> site..."
                                      >> Regards
                                      >> John Waller
                                      • 16. Re: Table size and content issues
                                        Level 7
                                        gud
                                        Walt
                                        "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                                        news:gbg9dj$5h5$1@forums.macromedia.com...
                                        > oic
                                        >> new dat
                                        >> Walt
                                        >>> site..."
                                        >>> Regards
                                        >>> John Waller
                                        • 17. Re: Table size and content issues
                                          Level 7
                                          Ha ha, Walt, he likes the way you wrote that just fine. So much for your
                                          sarcasm. :-D
                                          Patty Ayers | www.WebDevBiz.com
                                          Free Articles on the Business of Web Development
                                          Web Design Contract, Estimate Request Form, Estimate Worksheet
                                          news:gbf9sv$qjd$1@forums.macromedia.com...
                                          • 18. Re: Table size and content issues
                                            Level 7
                                            Don't worry, this entire thread is lost on me.
                                            Deciphering the 'texting' posts is like cracking a message from the Enigma
                                            machine :-)
                                            Regards
                                            John Waller
                                            • 19. Re: Table size and content issues
                                              Level 7
                                              Harder. You don't have a Polish POW to help you out.
                                              news:gbgrpf$s4g$1@forums.macromedia.com...
                                              > machine :-)
                                              > Regards
                                              > John Waller
                                              • 20. Re: Table size and content issues
                                                hii gary..thanks for the reply..i will surely look and change the cellpad to 0..if there is any further problem i will get back to you..i am totally new to this field and just trying to develop the site..so i am in a learning process you can say..i am also facing problem in the login form..i want to use ms acess for the database.i am facing problem in connectivity..as i dont have sql server..so please help me doing this also..i want to create a registration form also where users can register and login and be able to upload their files n all..thanks once again..
                                                • 21. Re: Table size and content issues
                                                  Level 7
                                                  You don't need SQL server to use Access as a data source.
                                                  > files n all
                                                  Honestly speaking, it will be a *long* time before you are ready to manage
                                                  this. Get busy studying your HTML and CSS now. The server-side stuff will
                                                  come much later.
                                                  news:gbhql4$45o$1@forums.macromedia.com...
                                                  > to
                                                  > new to
                                                  > process
                                                  > acess
                                                  > form
                                                  > n
