4 Replies Latest reply on Jun 28, 2009 6:41 AM by marc.bosch
    Can't resize window
    marc.bosch Level 1
      Hi there,
      perhaps somebody already solved this problem - a little help would be great :-)
      I have two monitors.
      On the left it's landscape, on the right it is pivot (1440x900 and 900x1440).
      The Premiere Window always starts on the pivot-monitor (monitor 1) and then can't be resized to the aspect ratio and resolution of the main window which is landscape.
      Operating System: Windows Vista
      Regards,
      Marc
        • 1. Re: Can't resize window
          Steve Grisetti-JFIrXo Adobe Community Professional & MVP
          Is the Premiere Elements window maximized? If so, make it a floating window and it should open in the same spot on your desktop every time. (Otherwise it will open in your #1 monitor.)
          At least that's how it works in XP. I don't know about Vista.
          • 2. Re: Can't resize window
            marc.bosch Level 1
            Hi Steve,
            thanks for helping.
            I just added a few photos to show what happens.
            1. DSCF3703.JPG  the Premiere Elements 7 window opens maximized on my right-hand screen (pivot)
            2. DSCF3704.JPG I minimize it and pull it over on the left-hand screen
            3. DSCF3705.JPG when trying to maximize it on the landscape left-hand-screen, it stays in the pivot-aspect-ratio
            Do you see the problem? :-)
            Regards,
            Marc
            • 3. Re: Can't resize window
              My guess is that the program is using the #1 screen as reference for defining itself as maximized. (In the same way, the Windows background you're using is likely either landscape on both monitors or portrait.)
              If you keep it a floating window and don't maximize it, you should be able to place and size it as you'd like.
              • 4. Re: Can't resize window
                marc.bosch Level 1
                Already tried to fix the size by myself by not maximizing it and then pulling it into the size I want.
                No chance - it stays in pivot-aspect-ratio.
                This is what I also tried:
                1.
                I also tried to switch screens in Windows so that screen 1 was screen 2 and the other way round.
                So I thought it would take the landscape screen as reference.
                No chance - doesn't work
                2.
                I tried to switch the screens positions so that the left screen appeared right in Windows and the other way round.
                No change - it keeps opening on the pivot-screen.
                3.
                I also switched off the pivot-screen and it started on the landscape screen because it was the only screen available.
                Yahoooo!
                BUT when I switch on the pivot screen it resizes and jumps over to the pivot-screen.
                HELP!
