3 Replies Latest reply on Aug 14, 2009 6:25 PM by GA-Sembada
    Center window in screen
      I have a program with a fixed resolution of 940 x 600 px. I would like it to be centered in the screen the first time it opens, no matter wich resolution the screen has.
      I allready found a code for this in the AIR cookbook, but it's for Flex. I would need something that uses JavaScript and HTML.
      Just a property that gives me the screens height and width!
        • 1. Re: Center window in screen
          anirudhs Level 2
          You can get the screen bounds via window.runtime.flash.display.Screen.mainScreen.visibleBounds.
          • 2. Re: Center window in screen
            jbenson@oper8 Level 2
            here's some additional code etc.
            function centerWindow(){
                        //default bounds of nativeWindow
                        var applicationBounds = window.nativeWindow.bounds;
                        //determine which screen we're located on
                        var screens = air.Screen.getScreensForRectangle(window.nativeWindow.bounds);
                        var screenBounds = (screens.length > 0) ? screens[0].visibleBounds : air.Screen.mainScreen.visibleBounds;
                        //get initial position
                        x = (screenBounds.width - applicationBounds.width) / 2;
                        y = (screenBounds.height - applicationBounds.height) / 2;
                        //adjust for offset x or offset y (multi monitors)
                        x = screenBounds.x + x;
                        y = screenBounds.y + y;
                        window.nativeWindow.x = x;
                        window.nativeWindow.y = y;
            • 3. Re: Center window in screen
              Hi Jason,
              It works for me. I put those line of codes and load it using "onload" event in <body>.
              although it works, but i'm finding another method to call the function.
              Is there any other way?
              Thank you for the codes, it helps me a lot.
