7 Replies Latest reply on Dec 16, 2010 9:28 AM by claytongulick
    Flex dynamic chart animation
    ramace
      Is it possilbe to add animations to dynamically created charts ?
      I tried giving series slide but was not successful.
      Is there an link which I can follow.
      Thanks in advance
        • 1. Re: Flex dynamic chart animation
          Fis Forums Level 1
          Use this code under
          <piechart>
              <pieseries>
                  <series>
                      <mx:showDataEffect>
          Note : Use any one of the property inside showtdataeffect tag
                        <mx:SeriesSlide duration="1000"/>
                        <mx:SeriesZoom duration="2000"/>
                        <mx:SeriesInterpolate duration="2000"/>
                    </mx:showDataEffect>
                </series>
            </pieseries>
            </piechart>
          • 2. Re: Flex dynamic chart animation
            ramace Level 1
            yes, this is possible only when I am creating chart in mxml.
            but the problem I am facing is my entire chart is created in actionscript and I tried these showdataeffect in actionscript but didn't work for me.
            Thanks for the reply.
            • 3. Re: Flex dynamic chart animation
              ramace Level 1
              Does any one have the solution for this ?
              Thanks in advance.
              • 4. Re: Flex dynamic chart animation
                rgadiparthi Level 2
                try this
                seriesId.setStyle("showDataEffect", myAnimation);
                <mx:SeriesInterpolate id="myAnimation" duration="1000" />
                • 5. Re: Flex dynamic chart animation
                  ramace Level 1
                  After a lot of trial and errors, I finally got it working.
                  The problem was, as my chart was getting created through actionscript so the effect was not visible.
                  i.e: The code was doing something like this
                  <instantiate a chart>
                  <set dataprovider for chart>
                  <add series to chart>
                  <add showDataEffect to series>
                  <add the chart to parent>
                  The working code looks somewhat like this.
                  <set some timeout say 1000 ms>
                  <set dataprovider for chart> --- the catch
                  This worked for me
                  Thanks for all ur contributions
                  • 6. Re: Flex dynamic chart animation
                    trisweb2 Level 1
                    Thank you for this post - I would have spent hours trying to figure out that you need a delay before setting the dataProvider.  It turns out that the delay required is not a time, but simply a frame. So using callLater() works perfectly for this situation:
                    var animation:Effect = new SeriesInterpolate();
                    animation.duration = 500;
                    series.setStyle("showDataEffect", animation);
                    callLater(setDataProvider);
                    private function setDataProvider():void {
                        chart.dataProvider = chartProvider;
                    Thanks again, very useful info.
                    • 7. Re: Flex dynamic chart animation
                      claytongulick
                      Thanks for the callLater tip, solved a brutal bug.
