7 Replies Latest reply on Jun 29, 2009 6:46 AM by flx23
    Binding data from db to ComboBox
    flx23 Level 1
      Hi all,
      I am new to flex
      I am having a table in sqlite having 4 column namely :-
      id, name, color, changed
      I am displaying name in the combobox for selection ..further what i want is to bind the id with it
      like if the user selects a name from the combobox then i should save the corresponding id for that name in the db
      user is just able to see the name not id..so is there any property where i can define this id..and further save it on selection of name from the user
      HERE is MY CODE:--------------------------------
      private function dropEvt(event:DropdownEvent):void
                      Txttest.text+=event.type + "\n";
                  private function changeEvent(event:Event)
                      Txttest.text+=event.currentTarget.selectedLabel + " " +
                     event.currentTarget.data + "\n";
                  private function init():void
                      var IFolder:IFolders=new FolderService();
                      _data=IFolder.GetDrawers();
                      CombBxDrawerName.dataProvider=_data;
                      CombBxDrawerName.labelField="strDrawerName";  // this is displayed to the id
                      CombBxDrawerName.data="intDrawerID";   // i need a properrty to assign id..that is hidden and can be saved on selected
      PLEASE HELP
      DESIGN:----------------------------------------
      <mx:ComboBox open="dropEvt(event)" close="dropEvt(event)"
      change="changeEvent(event)" id="CombBxDrawerName" x="180" y="20" width="185"/>
        • 1. Re: Binding data from db to ComboBox
          chris.huston.t10 Level 3
          Create your data model by assigning your sqlite data to an ArrayCollection. The ArrayCollection would be a collection of objects, with each object having id, name, color, and changed properties. The resulting ArrayCollection would look like this:
          private var dbData:ArrayCollection = new ArrayCollection([{id:1, name:'name 1', color:23456, changed:0}, {id:2, name:'name 2', color:45642, changed:1}, ...]);
          Depending on how you are accessing your sqlite data, you could just assign the db data directly to an ArrayCollection or cast it as an ArrayCollection.
          Then,you can bind this ArrayCollection to your ComboBox and display the name property while being able to access all the properties of a selected item.
          <mx:ComboBox open="dropEvt(event)" close="dropEvt(event)" dataProvider="{dbData}" labelField="name"
          To get the name and id of a selected item from the ComboBox:
                          Txttest.text+=event.currentTarget.selectedItem.name + " " +
                         event.currentTarget.selectedItem.id + "\n";
          Chris
          • 2. Re: Binding data from db to ComboBox
            Gregory Lafrance Level 6
            You could also use XML and e4x syntax to extract the data field for the ComboBox.
            Use HTTPService to get the data from the database, and then in the HTTPService result handler put the query result in an XMLListCollection object. Then use that XMLListCollection object as the ComboBox dataProvider.
            If this post answers your question or helps, please mark it as such.
            • 3. Re: Binding data from db to ComboBox
              flx23 Level 1
              well the data is coming from db using the following bold code
              it returns array how to bring arraycollections then
              public function ResultSetWithArrayCollection(SqlStmnt:SQLStatement):void
                          _statement=new SQLStatement();
                          _statement=SqlStmnt;
                          _statement.sqlConnection=_connection;
                          _statement.addEventListener(SQLEvent.RESULT, onQueryResultWithCollection);
                          _statement.addEventListener(SQLErrorEvent.ERROR, selectError);
                          _statement.execute();
                        private function onQueryResultWithCollection(event:SQLEvent):void
                          _dataCollection = _statement.getResult().data;  // it return array not arraycollection  return type of data is array..
                          dispatchEvent(event);
                     public function get dataCollection():ArrayCollection
                          return _dataCollection;
                      public function set dataCollection(resultCollection:ArrayCollection):void
                          _dataCollection = resultCollection;
              • 4. Re: Binding data from db to ComboBox
                Okay, then in your case stick with ArrayCollection and the previous reply should help. You can wrap an array in an ArrayCollection with:
                var ac:ArrayCollection = new ArrayCollection(myArray);
                • 5. Re: Binding data from db to ComboBox
                  Change your result function:
                              var _dataCollection:ArrayCollection = new ArrayCollection(_statement.getResult().data);
                            CombBxDrawerName.dataProvider=_dataCollection;
                  Each of the ArrayCollection items will now be bound to your ComboBox. You can choose to display whichever of the item properties you want while still having access to all of the properties.
                  Chris
                  • 6. Re: Binding data from db to ComboBox
                    flx23 Level 1
                    Ok i have done this now:-
                                  var    arcol:ArrayCollection=new ArrayCollection(_statement.getResult().data);
                                _dataCollection=arcol;
                    and binding it with combobox like this
                    Now my question is how to display the name and id
                    the above code displays [object] in the combo box
                    do i have to change something in design code :- .....????????????
                    change="changeEvent(event)" id="CombBxDrawerName" x="180" y="20" width="185">
                    <mx:ArrayCollection>
                             <mx:Object label="{strDrawerName}" data="{intDrawerID}"/>
                          </mx:ArrayCollection>
                    </mx:ComboBox>
                    • 7. Re: Binding data from db to ComboBox
                      flx23 Level 1
                      thanks a lot guys...i got it
                      while displaying do this:----
                                   //CombBxDrawerName.text="intDrawerID";
                      and while to fetch id or name what ever you want do this
                                     event.currentTarget.selectedItem.intDrawerID+ "\n";
