1 Reply Latest reply on Jun 29, 2009 7:51 AM by [Jongware]
    Select multiple frames in jscript
    Techi Panda Level 2
      Hi Scripters
      I am trying to select two frames one is text frame next one is graphic frame. I need to select both and make them center alignment in javascript.
      anyone advice me how to do this?
      thanks in advance
      a r u l
        • 1. Re: Select multiple frames in jscript
          Usually, you don't have to select items in javascript, you can apply anything you want directly. But if you need it, it's the [item].select ([selectionOptions]) method, available for any graphic object.
          If a is your text frame and b you graphics frame, it comes down to
          a.select (); // SelectionOptions.REPLACE_WITH is the default
          b.select (SelectionOptions.ADD_TO);
          You can set the text alignment of the text frame to centered, but not that of the graphics frame -- it's a text only attribute (to be precise, a Paragraph property). Given the selection above, of a text frame and a rectangle (ID doesn't care if it contains a graphic or not, as long as it does not contain text),
          app.selection[0].paragraphs.everyItem().justification = Justification.CENTER_ALIGN;
          sets the paragraph alignment for the text in frame (a) but -- rather obviously -- not in frame (b).
