0 Replies Latest reply on Jun 29, 2009 6:25 AM by RGB
    Problem with Maintaining Frame Hold Using Rate Stretch Tool
    RGB Level 1
      In previous CS versions of Premiere you are able to create a frame hold of a clips out point in order to create and freeze frame, and then using the Rate Stretch tool modify the duration of the freeze frame without altering the out point.
      In my version of Premiere CS4, the Rate Stretch tool DOES NOT maintain the out point of my frame hold. Has anyone else encountered this problem? If so, have you been able to correct it?
