1 Reply Latest reply on Jun 29, 2009 1:55 PM by camfieldaj
    Main app and sub SWF apps
    rckehoe
      Is there any way to send variables between SWF apps?
      Let me explain...
      I have an application that has a list box of items that you can select. When you select one of these items from the list box, it will load a different SWF file. I want to be able to pass variables to this remote SWF file, this way the SWF file can use these variables....
      Is that possible?
        • 1. Re: Main app and sub SWF apps
          camfieldaj
          Yes, I'm pretty sure you can pass messages back and forth between two separate applications, but the way I ususally do this is to have a main application that loads and unloads modules. In the main swf, the one defined as the application I have global variables that can be accessed from any of the modules. so, to retreive the value your syntax would be:
          var localvar:String=Application.application.globalVar;
          Hope this helps.
