10 Replies Latest reply on Jun 30, 2009 2:53 PM by Schlamazel
    Remote call to a button
    Schlamazel
      Is it possible to call button click event remotely from a change in the text input?
              <![CDATA[
                  import spark.events.TextOperationEvent;
                  import mx.controls.Alert
                  protected function button1_clickHandler(event:MouseEvent):void
                      Alert.show ("Hello World")
                  protected function textarea1_changeHandler(event:TextOperationEvent):void
                      // HOW TO CALL THE ABOVE BUTTON CLICK FROM HERE?
          </fx:Script>
      Thank you,
      GT
        • 1. Re: Remote call to a button
          oldMster Level 3
          Unless you specifically need data in the MouseEvent type event to do the button1_clickHandler(event...., change it's expected event type to plain old Event, then you can call the function from the textarea function:
                  <![CDATA[
                      protected function button1_clickHandler(event:Event):void
                         button1_clickHandler(event);
              </fx:Script>
          • 2. Re: Remote call to a button
            *Prashant Shelke* Level 4
                           button1.dispatchEvent(new MouseEvent(MouseEvent.CLICK));
            • 3. Re: Remote call to a button
              EgorKDie Level 2
              If you don't need the event object, you can make it even easier than that!
              <![CDATA[
                          protected function button1_clickHandler(event:MouseEvent = null):void
                             // LIKE THIS!
                             button1_clickHandler();
                  </fx:Script>
              note the "= null" in the click handler, this defaults the value of the event to null if you don't specify one yourself, so you can just leave it out when you call it!
              • 4. Re: Remote call to a button
                Schlamazel Level 1
                Great! This works. Thank you!
                • 5. Re: Remote call to a button
                  EgorKDie Level 2
                  Mark one of us as correct then! We are all dying to know which way you chose to do it
                  • 6. Re: Remote call to a button
                    Schlamazel Level 1
                    *This works! *
                    <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://
                    ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/halo"
                    minWidth="1024" minHeight="768">
                    <fx:Script>
                    <![CDATA[
                    // Call the above button click
                    </fx:Script>
                    <s:Button x="155" y="138" label="Button"
                    click="button1_clickHandler(event)" id="button1"/>
                    <s:TextArea x="101" y="184" change="textarea1_changeHandler(event)"/>
                    </s:Application
                    • 7. Re: Remote call to a button
                      martinjconnolly Level 1
                      couldn't you just do this?
                      protected function showMessage():void {
                      showMessage();
                      showMessage();
                      • 8. Re: Remote call to a button
                        oldMster Level 3
                        If all that was desired was a simple task that didn't need any values from the actual event, then yes, that would work.  Since more complex actions are probably the actual desired result, the answer marked as the 'correct' answer is the best answer provided, because it eliminates duplication of code, and still provides full access to the Mouse 'Click' event, whichever method of firing the function is used.
                        Mark
                        • 9. Re: Remote call to a button
                          Your wel-come
                          • 10. Re: Remote call to a button
                            Schlamazel Level 1
                            I understand. Thank you.
                            Glenn
