11 Replies Latest reply on Jul 7, 2009 9:06 AM by escouten
    VERSION
    micahjwalter
      I was trying to set the VERSION number in my Info.lua file as follows:
      VERSION = {
      1,1,4
      but I must be doing this wrong as it keeps showing up as Version 1.0 in the Plugin-Manager. Any examples of how this should be formatted?
      -m
        • 1. Re: VERSION
          Mark J M Wilson Level 1
          It was documented on page 21 of the 2.2 SDK manual update and there is an example of syntax in the flickr.lrdevplugin:
          VERSION = { major=2, minor=0, revision=0, build=200000, },
          You can also specify 'display' to show something different or localise the displayed string.
          Hope that helps.
          • 2. Re: VERSION
            john beardsworth Adobe Community Professional & MVP
            As a follow up, is it possible for the plug-in to detect the version - and therefore use an LrHTTP call to show a "newer version available" message in the Info panel?
            I've tried _PLUGIN.version, _PLUGIN.VERSION. Neither of which are documented, and neither of which work.
            John
            • 3. Re: VERSION
              John, I ended up with a long winded solution to that: I store major, minor, revision and build in a table, which I use to set the version info.  I can then use the same values to compare to the latest released value on my website.
              BTW John, I saw your comment on my tagset issue - thanks and looking at it now.
              • 4. Re: VERSION
                Thanks  Mark, that gives me a way forward. Can't get it to work
                though!
                John
                • 5. Re: VERSION
                  I just realised that my explination was bad and that LrApplication.versionTable() might do what you want...and I am trying to remember why I am not using versionTable()...I really should write more comments in my code...
                  I actually store the values in two places - once in info.lua and again in another script, which now makes no sense at all but was probably very sensible last year
                  EDIT: just realised why - it gives Lightroom's version, not the plug-in's...
                  Message was edited by: Mark J M Wilson
                  • 6. Re: VERSION
                    Isn't that the version of Lightroom?
                    John
                    • 7. Re: VERSION
                      John
                      Yes, my edit must have crossed with your reply.  That does explain why it is commented out in my code and replaced with a recreation of the version table.
                      • 8. Re: VERSION
                        escouten Adobe Employee
                        Those calls aren't documented because they aren't implemented.
                        There isn't currently a way for a plug-in to look at its Info.lua declaration or its version declaration. I'll interpret this as a feature request for such.
                        • 9. Re: VERSION
                          DawMatt Level 3
                          Not technically true.
                          Why don't people just do this?  My latest plugin uses it and it works.
                          local info = require 'Info.lua'
                          local versionString = 'Version ' .. (info.VERSION.major or '0') .. '.' .. (info.VERSION.minor or '0')
                          Sure, Lightroom has to have this in memory already so this is a tad inefficient, but the files are small (and have to be present) so its relatively save to load them again.
                          Matt
                          • 10. Re: VERSION
                            Thanks Eric - that's a correct interpretation.
                            • 11. Re: VERSION
                              D'oh! I stand corrected.
                              I don't see any problem with this approach.
