12 Replies Latest reply on Jul 8, 2009 1:05 AM by kel45
    event gateway handling
    kel45 Level 1
      Hi i am using the main.cfc in the examples using the onIncomingMessage event
      i am gettnig back a variable
      <cfset message="#data.message#">
      <!--- where did it come from? --->
      <cfset orig="#CFEvent.originatorID#">
      <cfset retValue = structNew()>
      <cfset retValue.command = "submit">
      <cfset retValue.sourceAddress = arguments.CFEVENT.gatewayid>
      <cfset retValue.destAddress = arguments.CFEVENT.originatorid>
      <cfset retValue.shortMessage = "echo: " & message>
      retValue.shortMessage contains all the data and is then written to a text file like this
      "Information","Thread-15","06/30/09","21:07:17","IM_MENU","echo: id:869990453 sub:001 dlvrd:001 submit date:0906301507 done date:0906301507 stat:DELIVRD err:000 text:"
      what i need is to set 2 variables
      1. MessageId = this is the "id" in the echo
      2. MessageStatus = this is the "stat"
      i am not sure how to get to this info?
        • 1. Re: event gateway handling
          Dileep_NR Level 2
          could you please paste ur main.cfc
          • 2. Re: event gateway handling
            kel45 Level 1
            main.cfc below, instead of writing to a txt file i need to create 2 variables to insert into my database
            <cffunction name="onIncomingMessage" output="no">
            <cfargument name="CFEvent" type="struct" required="yes">
            <!--- Get the message --->
            <cfset data=cfevent.DATA>
            <cfset retValue.shortMessage = "echo: " & messageId>
            <cflog file="smsTest" text="#retValue.shortMessage#">
            </cffunction>
            • 3. Re: event gateway handling
              mack_ Level 3
              ReFindNoCase("id:() .*stat:() ", retValue.shortMessage, 1,
              true) will get you the position and length of the id and stat in the
              message (you can use Mid to extract them).
              Mack
              • 4. Re: event gateway handling
                Dileep_NR Level 2
                try this
                <cfset temp= listgetat(retValue.shortMessage,6)>
                <cfset temparray= listtoarray(temp," ")>
                <cfset MessageId  = listgetat(temparray[2],2,":")>
                <cfset MessageStatus  = listgetat(temparray[9],2,":")>
                • 5. Re: event gateway handling
                  kel45 Level 1
                  Hi i have tried the below, which did not work, i am not sure how i can debug this to find what the error is, as its a event?
                  <cfcomponent>
                  <cflog file="smsTestCraig2" text="#MessageStatus#">
                  </cffunction>
                  • 6. Re: event gateway handling
                    mack_ Level 3
                    Use cflog to save information about the request to a log file.
                    Here's the same statement as above but this time correctly escaped in code tags:
                    ReFindNoCase("id:([0-9]+) .*stat:([a-z]+) ", retValue.shortMessage, 1, true)
                    Mack
                    • 7. Re: event gateway handling
                      kel45 Level 1
                      ok thanks i have added the following, but nothing is written to the log file
                      <cflog file="smsTestCraig2" text="#ReFindNoCase("id:([0-9]+) .*stat:([a-z]+) ", retValue.shortMessage, 1, true)#">
                      • 8. Re: event gateway handling
                        mack_ Level 3
                        That's because the ReFindNoCase returns a structure and the text
                        attribute expects a string (or something that can be converted to a
                        string).
                        Test the regular expression outside the cfc, in a simple test file to
                        make sure it's working properly and place the code inside the CFC
                        after that.
                        Mack
                        • 9. Re: event gateway handling
                          Dileep_NR Level 2
                          try this
                          <cfset st1=ReFindNoCase("id:([0-9]+) .*stat:([a-z]+) ", retValue.shortMessage, 1, true)>
                          <cfloop index = "i" from = "2" to = "#ArrayLen(st1.pos)#">
                              <cfset testval  = testval & Mid(t,st1.pos[i],st1.len[i]) & "|">
                          </cfloop>
                          <cflog file="smsTestCraig2" text="#testval #">
                          • 10. Re: event gateway handling
                            kel45 Level 1
                            ok i have tried the following in a test file, but i just get 2 empty strings?
                            <cfset retValue.shortMessage = "echo: id:869990453 sub:001 dlvrd:001 submit date:0906301507 done date:0906301507 stat:DELIVRD err:000 text:">
                            <cfset testval = "">
                                <cfset testval = testval & Mid(true, st1.pos[i],st1.len[i]) & "|">
                            </cfloop>
                            <cfdump var="#testval#">
                            • 11. Re: event gateway handling
                              mack_ Level 3
                              The first parameter of the Mid function is not a boolean but the
                              string from which you want to extract the substring.
                              Mack
                              • 12. Re: event gateway handling
                                kel45 Level 1
                                hi so what should the first value be?
                                i have tried st1?
