7 Replies Latest reply on Jun 30, 2009 12:47 PM by kglad
    How to play next song
    alexManuelSilva
      I am trying to build a simple player inside my swf file. The code is a bit messy but it seems to work.
      I´m using a soundChannel for Playback..
      I´m trying to figure out how to have the player play the next song once the previous one has reached its end.
      Do I add some sort of EventListener to the soundChannel?
      Thanks for helping
      import fl.transitions.*;
      import fl.transitions.easing.*;
      prevBt.buttonMode=true;
      playBt.buttonMode=true;
      stopBt.buttonMode=true;
      nextBt.buttonMode=true;
      pauseBt.buttonMode=true;
      pauseBt.visible=false;
      var xmlLoader:URLLoader= new URLLoader;
      var temasURL:URLRequest= new URLRequest ("temas.xml");
      xmlLoader.addEventListener(Event.COMPLETE, xmlLoaded)
      xmlLoader.load(temasURL);
      var temasXML:XML = new XML();
      temasXML.ignoreWhitespace=true;
      function xmlLoaded(e:Event):void{
            temasXML =XML(xmlLoader.data);
            var temaNum:Number=0;
            var tema:String = temasXML.tema[temaNum].mp3;
            var musica:Sound = new Sound(new URLRequest("audio/"+ tema))
            var sc:SoundChannel;
            var isPlaying:Boolean = false;
            var pos:Number=0;
            stopBt.addEventListener(MouseEvent.CLICK, parar_musica);
            function parar_musica(e:MouseEvent):void{
                  sc.stop();
                  isPlaying=false;
                  playBt.visible=true;
                  pos=0;
            playBt.addEventListener(MouseEvent.CLICK, tocar_musica);
            function tocar_musica(e:MouseEvent):void{
                  pauseBt.visible=true;
                  playBt.visible=false;
                  if(!isPlaying){
                       sc= musica.play(pos);
                       isPlaying=true;
                       playerTx.text=temasXML.tema[temaNum].legenda;
           pauseBt.addEventListener(MouseEvent.CLICK, pausa_musica);
           function pausa_musica(e:MouseEvent):void{
                 if (isPlaying){
                     pos=sc.position;
                     sc.stop();
                     isPlaying=false;
           nextBt.addEventListener(MouseEvent.CLICK,seguinte);
           function seguinte(e:MouseEvent):void{
                  sc.stop();
                  temaNum +=1;
                  musica= new Sound(new URLRequest("audio/"+ (temasXML.tema[temaNum].mp3)))
                  sc= musica.play();
                  isPlaying=true;
           prevBt.addEventListener(MouseEvent.CLICK,anterior);
           function anterior(e:MouseEvent):void{
                  sc.stop();
                  temaNum -=1;
                  sc= musica.play();
                  isPlaying=true;
        • 1. Re: How to play next song
          the sound class has a complete event you can use:
          musica.addEventListener(Event.COMPLETE,f);
          function f(e:Event){
          //play next
          • 2. Re: How to play next song
            alexManuelSilva Level 1
            Thanks Kglad.
            That's what I was looking for.
            • 3. Re: How to play next song
              It doesn´t seem to be working after all.
              apparently, it is not possible to add an EventListener to a Sound class, or is it?
              I tried
              //play next
              but it does nothing...
              thanks, anyway
              • 4. Re: How to play next song
                are defining the listener AFTER musica is defined?
                • 5. Re: How to play next song
                  if I declare:
                       var musica:Sound;
                  then add the EL:
                        musica.addEventListener(Event.COMPLETE, song_ended)
                        function song_ended(e:Event):void{
                              trace("finished");
                              isPlaying=false;
                  and finally load the sound into the variable:
                  I get this error message:
                       TypeError: Error #1009: Der Zugriff auf eine Eigenschaft oder eine Methode eines null-Objektverweises ist nicht möglich.
                        at index1_fla::player_33/xmlLoaded()
                        at flash.events::EventDispatcher/dispatchEventFunction()
                        at flash.events::EventDispatcher/dispatchEvent()
                        at flash.net::URLLoader/onComplete()
                       (sorry about the untranslated text, I bought this laptop in Germany)
                  which leads me to think that the COMPLETE event in the Sound Class is related to the loading of the sound rather then the playing of the sound (correct me if I´m wrong).
                  On the other hand,
                         var musica:Sound = new Sound(new URLRequest("audio/"+ (temasXML.tema[temaNum].mp3)))
                              trace("finished");
                              isPlaying=false;
                  doesn´t work either. As a matter of fact, after I´ve written:
                  it´s as if I can no longer add an Ev Listener (it´s not there on the list of options anymore)
                  • 6. Re: How to play next song
                    I´ve just figured it out
                    the soundChannel has the event I was looking for:
                      sc.addEventListener(Event.SOUND_COMPLETE, song_ended);
                    • 7. Re: How to play next song
                      oops, you're correct.
                      the sound's complete event fires when the sound completes downloading, not when it completes play.
