• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RH7 Generated HTML in Linux -- upper/lower case letters
New Here ,
Jun 30, 2009 Jun 30, 2009
I have a RH7 project created in WinXP.  I need to be able to put the generated HTML files onto linux.  For the most part things work OK.  However there are issues due to case sensativity of filenames of some of the images and generated html files.  There are approximately 30 instances where robohelp generated a filename with a different combination of upper/lower case letters than is used in the links (<A> and <IMG> tags) within the generated HTML.  This results in some images not being displayed in the web page and some links broken.  (For example, we have an html file being generated called, "HydGraphView.htm" while a link to it uses the name "hydgraphview.htm").
Is there a way to force robohelp to do something like use all lower case letters when generating the html file and the links?
I have tried changing the names of the files in the properties for the individual help pages, but when I close the properties dialog then reopen it the mixed case filenames are restored.  It appears that robohelp is not actually recognizing that I've changed the filename given that I'm only changing the case of the letters.
Thanks for your help
Views
497
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
On the first page of the wizard there is an option to force all filenames to lowercase. Provided you are not talking about merged help, RH will also change the links to lowercase and that should fix your problem.
Votes
Translate
Translate
Report
Report
New Here ,
I'm sorry, I guess I neglected to state that we're using an automated build system so we're using the rhcl.exe command to generate our web help.  We haven't seen any sort of command-line switch to force all lower-case.  Is there another way to do this?
Thanks again.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
I don't use that but doesn't it specify one of the layouts? If so, set that layout as advised.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
