• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Graphing multiple sets of data
Guest
Aug 04, 2008 Aug 04, 2008
I am running an auction site and wish to display the bids for each supplier in a line graph. the following code will display just one line on the graph. i need it to show a different line (with different color) for each supplier and their bids. is there a way to group by in cfchart? or do i need to do a cfloop query?
<CFQUERY NAME="GetChartData" DATASOURCE="#Application.Datasource#">
SELECT Bids.BidID, Bids.SupplierID, Bids.AuctionID, Bids.Bid, Bids.Bid_Date, Suppliers.Company
FROM Bids INNER JOIN Suppliers ON Bids.SupplierID = Suppliers.SupplierID
WHERE Bids.AuctionID=<CFQUERYPARAM VALUE="#URL.AuctionID#" CFSQLTYPE="CF_SQL_VARCHAR" MAXLENGTH="50">
ORDER BY Bids.Bid_Date ASC;
</CFQUERY>
<cfchart format="flash" chartheight="400" chartwidth="500" scalefrom="0" scaleto="50" seriesplacement="default" showborder="yes" labelformat="number" xaxistitle="Date/Time" yaxistitle="Bid Amounts" tipstyle="mouseOver">
<cfchartseries type="line" query="GetChartData" itemcolumn="Bid_Date" valuecolumn="Bid" serieslabel="E-Auction" seriescolor="FF00FF" markerstyle="circle" />
</cfchart>
TOPICS
Advanced techniques
Views
588
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
<cfchart>
<cfloop query="yourquery">
<cfquery dbtype="query">
<cfchartseries>
closing tags
Votes
Translate
Translate
Report
Report
Guest
i've tried the following but i get a really thick red line - not separate lines of different colors. plus the whole page takes ages to fully load as well.
<cfchart format="png" chartheight="400" chartwidth="500" scalefrom="0" scaleto="50" seriesplacement="default" showborder="yes" labelformat="number" xaxistitle="Date/Time" yaxistitle="Bid Amounts" tipstyle="mouseOver">
<cfloop query="GetChartData">
<cfquery dbtype="query" name="GetChartData2">
select * from GetChartData
</cfquery>
<cfchartseries type="line" colorlist="purple,blue,green,yellow,gray,silver,teal" query="GetChartData2" itemcolumn="Bid_Date" valuecolumn="Bid" seriesColor="red" serieslabel="E-Auction" markerstyle="circle" />
</cfloop>
</cfchart>
Votes
Translate
Translate
Report
Report
LEGEND ,
Your Q of Q needs a where clause.
Votes
Translate
Translate
Report
Report
Guest
i put in a where statement but no difference.
<!--- Query to find Data for the Chart --->
</CFQUERY>
where SupplierID IN (<CFQUERYPARAM VALUE="#GetAuctions.Suppliers#" LIST="YES" CFSQLTYPE="CF_SQL_VARCHAR">)
</cfquery>
</cfloop>
</cfchart>
GetAuctions.Suppliers is a comma delimited list of the Supplier ID's.
Votes
Translate
Translate
Report
Report
LEGEND ,
Put an index attribute in your cfloop tag.
Use it in the where clause of your query.
Votes
Translate
Translate
Report
Report
Guest
Aug 08, 2008 Aug 08, 2008
I had to leave this for a few days but I have just tried the following code and it works to the extent that there is a different coloured line for each supplier on the chart but it seems that each supplier has its own time axis. I need it to show one time axis on the bottom, with all bids, regardless of supplier plotted along that, with each individual supplier uniquely identified by a colour.
</CFQUERY>
<cfset Suppliers=ValueList(GetSuppliers.SupplierID)>
<cfchart chartheight="325" chartwidth="475" format="png" font="Arial" fontbold="Yes" scalefrom="0" scaleto="50" seriesplacement="default" showborder="yes" labelformat="number" xaxistitle="Date/Time" yaxistitle="Bid Amounts" tipstyle="mouseOver">
<cfloop index="ListSuppliers" list="#Suppliers#">
where SupplierID='#ListSuppliers#'
</cfquery>
<cfchartseries type="line" query="GetChartData2" itemcolumn="Bid_Date" valuecolumn="Bid" serieslabel="E-Auction"/>
</cfloop>
</cfchart>
Votes
Translate
Translate
Report
Report
Guest
Aug 11, 2008 Aug 11, 2008
I enabled sortxaxis as "yes" and it now works apart from the fact that the data points do not connect properly. it seems that they will connect until a different supplier puts a bid in. see example chart at: http://img166.imageshack.us/my.php?image=chartbidsxl8.jpg
<cfchart chartheight="325" chartwidth="475" format="png" font="Arial" fontbold="Yes" seriesplacement="default"
labelformat="number" showBorder="Yes" showLegend="Yes" showMarkers="Yes" sortxaxis="yes" xaxistitle="Date/Time" xaxistype="Category" yaxistitle="Bid Amount" tipstyle="mouseOver">
<CFLOOP INDEX="ListSuppliers" LIST="#Suppliers#">
<CFQUERY DBTYPE="query" NAME="GetChartData2">
SELECT * FROM GetChartData
WHERE SupplierID='#ListSuppliers#'
</CFQUERY>
serieslabel="#GetChartData2.Company#" markerstyle="circle" paintstyle="plain" />
</CFLOOP>
</cfchart>
Votes
Translate
Translate
Report
Report
Guest
Aug 12, 2008 Aug 12, 2008
LATEST
As each supplier has placed different bids at different dates/times, basically each chart series is unrelated to the other ones. The only thing they have in common is the ranges of the x and y data. It seems that unless the date values line up in the different series, then the graph won't display the series properly. Is there a way around this? is it possible in a case like this to make the x-axis values the same in all the data sets?
Votes
Translate
Translate
Report
Report
Resources
Documentation
