If I downloaded a free trial for Captivate 3 and then installed the licensed version on my computer...is it possible to download the free trial of captivate 4 as well?
Hi there
Things should work fine.
The only caveat I'm aware of is that installing the trial of version 4 will likely re-associate the .CP file extension with the newer version.
So if you are accustomed to locating the file you wish to edit using Windows Explorer, then double-clicking to open Captivate, version 4 will open and not 3. Personally I have never worked that way so the issue would be moot with me. But I know many folks do work that way. Which is why I posted what I did!
Cheers... Rick
Helpful and Handy Links |
Would I still be getting my full 30 days, because sometimes it does not give the full 30 days if you have already downloaded a previous free trial (i.e. captivate 3)
Hi there
I'd be silly if I said I was dead sure you will. All I can do is speculate. All I can do is advise that you *should* get the full 30 days. And if you don't, contact Adobe!
4 is a different beast, so I would think from the PC perspective, unless things are really wonky, it would be treated the same as a new app.
Cheers... Rick
Thank you so much - I will give it a try!
Can someone provide me with a valid link to download Captivate 4 for Win 7? I have a license key.
Thanks!
Hi Nlstinson,
Thanks for your intrest in captivate. We have replaced the Captivate 4 trial version with the latest available version of captivate i.e Captivate 5. You can download Captivate 5 from http://www.adobe.com/products/captivate/.The same window installer works for Window 7. But make sure that you run the same in admin mode to use all the features.
Subhransu
Hi Subhransu
I am trying to convert projects in Cp3 into Cp5. When the Cp3 projects open in Cp5 they are completely trashed. Frankly I am really dissapointed with the newer product which has given LOTS of headaches and extra work for no benefits (or none that I can see so far).
Other users on these forums have suggested that transition from Cp3 to Cp4 and finally to Cp5 to ease the transition.
Do you know if I can still get a trial of Cp4?
M
Hey M,
Go to this Link --
http://www.adobe.com/cfusion/tdrc/index.cfm?loc=en_us&promoid=DJDUI&product=captivate
Sign in With your Credentials, --
Then Replace the URL with this URL -- http://trials.adobe.com/Applications/Captivate/Adobe_Captivate_4_WWE.exe
and Hit "Enter" key.
It would begin Captivate 4 Installation.
Make sure you have back up of each project before you upgarde, as Cp does not support backward Compatibility.
Thank,
Anjaneai
