1 Reply Latest reply on Jul 1, 2009 7:21 AM by kglad
    template amendment to get text from xml and few other tweaks
    dave rumbelow
      I am working on a project based on the following template http://www.adobe.com/devnet/flash/articles/vidtemplate_corppreso_print.html and I would like some updates to it.
      I would like to enter the text via xml,
      When the video reaches a cue point I would like it to load text from an xml attribute of the same name, ie cuepoint A loads <item name="A">
      each xml will be bulleted list with up to 8 points which I would like to style globally, (css or similar), and add or remove points to make longer and shorter lists
      I would also like the animation to be standard so this can be modified project wide through actionscript or similar.
      what d'you reckon!
