1 Reply Latest reply on Jul 2, 2009 12:35 AM by seb foucault
    Unbound ItemRenderer
    seb foucault
      Hello,
      Is there a safe way to be notified that an item renderer used to render items in a tiled list (either horizontal or vertical list) is not used anymore (for instance when switching from a state in which the data provider contains one or more items to a state in which the data provider does not contain any item).
      Using Flex 3.0.x, I noticed that none of the following approaches works :
      • Intercepting the dataChange event - This event is not called when a previously bound item renderer is no longer used
      • Intercepting the flex.event.Event.REMOVE event - This event seems not to be called when the item renderer is removed from its parent
      • Intercepting the flash.event.Event.REMOVED event of the item renderer parent. Same. Not called.
      Any idea ?
      Thanks in advance - Regards
      sébastien foucault
        • 1. Re: Unbound ItemRenderer
          seb foucault Level 1
          I finally found a workaround consisting in intercepting the call to visible = false made by ListBase.addToFreeItemRenderers.
          It is not bullet proof but may help in some situations :
          public override function set visible( value: Boolean ): void {
             super.visible = value;
             if ( value == false ) {
                // doSomething
          sébastien
