3 Replies Latest reply on Jul 8, 2009 7:37 AM by Sentah
    FTP Put Component - How to create remote directory
    DyonisosDD
      Hello,
      I'm using LC ES Process Manager 8.2.1 and I'm trying to put files using FTP in a new remote directory.
      If I set the remote path to a non existing folder, the operation is crashing.
      I don't have found any solution to create remote folders.
      Do somebody know a way to achieve that?
      thanks!
      Denis
        • 1. Re: FTP Put Component - How to create remote directory
          Sentah
          Couple of things you might want to check is
          1) Does your username has the required permissions to create a new directory.
          2) Are you using the correct username/password combination.
          Make sure you paste the error you are getting.
          • 2. Re: FTP Put Component - How to create remote directory
            DyonisosDD2
            Hi Sentah,
            Thanks for your answer.
            My problem is mare that I don't have found any way in the FTP component component to create remote folders.
            I have tried to set the initial folder property, but the component is assuming that the entered path must exist.
            I also tried to put a path into the filename field but without success.
            Do you know if it's a way to create a remote directory or, in a  more way, to put directly a file in a new directory?
            As temporary solution, we have created a custom component to achieve that and it works, but that should be possible with standard components...
            Regards
            Denis
            • 3. Re: FTP Put Component - How to create remote directory
              Sentah Level 1
              Ok. If the custom component works then its got something to do with the ftp component setup you are doing.
              Can you paste me the screenshot of the ftp component properties ?
              Also the error message would help isoloating the issue.
