4 Replies Latest reply: Jul 1, 2009 3:19 PM by Eddie Lotter RSS
    Media Cashe Files & Media Chase Database?
    jdmoor Community Member
      I'm running:
      CS4 Production Premium
      Vista x64
      8Gig RAM
      Dell T4300 Workstation
      DuoCore 2.6Mhz
      1T System 7200rpm SATA HD
      4 - 7200rpm SATA HDs dedicated to Video Projects (2- 1.5T & 2- 500Gig)
      I started a new project Monday, captured 6 hours of video (3 cameras, 2 hours each of a Musical Performance).   As I was working yesterday, I noticed when I rendered, the 'render progress bar' would move (showing the progress), then pause for several seconds, move some more, then pause again, as if the renders were being written from RAM onto the HD.   "Normally", I see the render bar progress consistently, sometime slower than other times if the clips being rendered have filters, effects, etc., but I've never seen the progress bar simply pause before.
      Because I had (a couple weeks ago) changed my Media Cashe Files to "store next to originals when possible", I was thinking this may be the cause.  I've changed that back to the default (unchecked the box) but the condition still exist.   The "Media Cashe Database" is set to: "user\....\Adobe\Common".   As far as I remember, I've never messed with that before.   I also noticed the location for the "Scratch Disk" is listed in "user\....\Adobe\After Effects CS4".     Why would a PremierePro project have the "Scratch Disk" set under the AfterEffects folder?  (I changed this to "Same As Project".
      What is the "best" option for the two Project Preference settings for:
      1) Media Cashe Files
      2) Media Cashe Database
      TIA,
      jd
        • 1. Re: Media Cashe Files & Media Chase Database?
          Colin Brougham Community Member
          A hard drive that is separate from your system drive, your projects drive, and your primary media drive. Direct all media cache files and preview files to that drive. That's "best", anyway, at least in terms of performance.
          • 2. Re: Media Cashe Files & Media Chase Database?
            Thanks Colin,
            A couple of follow-up questions....since I've never really thought much about these options in previous versions of Premiere, do these files (for any given project) go away when the project is deleted or do I have to 'manually' delete these files after I delete a project?   I'm asking because I'm thinking of 'dedicating' one of those "500Gig SATA HDs" to store the Cashe and DB files and I assume it would fill-up after a while.
            Thanks again,
            jd
            • 3. Re: Media Cashe Files & Media Chase Database?
              No, you'd have to delete them. That's one benefit of storing the media cache files next to the originals, in that you can simply purge the entire directory of files when you're done with it. Splitting them up creates a bit of a file management issue, since Premiere really doesn't have a good way to selectively eliminate generated preview files. The Project Manager works to an extent, but it will still leave the originals behind. So as long as you set things up at the beginning of a project correctly, it'll make finishing and archiving the project a little easier. The good news is that if you delete a cached file that another project needs, it will be recreated automatically. Rendered previews would have to be manually recreated, however.
              • 4. Re: Media Cashe Files & Media Chase Database?
                Eddie Lotter Community Member
                You will also find several links to documents that describe how to optimize your workstation here.
                Cheers
                Eddie
