I need to create a table in my pdf that grows and will cross over to other pages if it gets big enough.
The table with look like this:
Header 1 | Header 2 | Header 3 | Header 4 |
Heading 1 | Total of all sub heading values under heading 1 | ||
sub heading 1 | value 1 | ||
sub heading 2 | value 2 | ||
sub heading 3 | value 3 | ||
(more sub headings need to be added if applicable |
So, what I need to figure out is how to allow the user to add more sub headings under heading 1 and still calculate the total values for all the sub headings under heading 1.
Is this possible? Any help is greatly appreciated!!!
Thanks in advance!
Views
Total Likes
I made some simple example for you. It could be start point for your form.
BR,
Paul Butenko
Views
Total Likes
Thank you so much for the example, that is wonderful!
Now, is there a way to say hide the sub heading row, and have the add row button under heading 1?
Because sometimes there might not be a subheading so I would like to have no subheading rows and
have the user just add them if they are needed if possible?
Also, can I set the value of the numeric field to 0 initially?
Thanks again!!!
Views
Total Likes
Is there a way to move the subform on the page? I wanted to create a header for each page on the master page, but I need to move the subform down the page. When I select it and drag it, it doesn't seem to move. How do you reposition it?
Views
Total Likes
to hide something use FieldName.presence = "hidden"
two ways:
1) on initialise event put this.rawValue = 0 - JS, $.rawValue = 0 - FormCalc
2) Object palette - Value tab - Default field put 0
You can use page breaks:
Click on subform , Object palette - Pagination tab
To put header on master page you will have to create separate table there.
BR,
Paul Butenko
Views
Total Likes
Hi Paul,
I've attached the file I am working with.
Regarding your responses, you said to use use FieldName.presence = "hidden"....
Where do you put that script. When I select the first row under heading 1 and in the object pallete
click chance presence to invisible, it just hides that columns, then when you click on "add row",
it duplicates the row without the columns.
I just want to hide the row under heading one and have the "add subrow" button under heading 1.
Is that possible?
2nd question....where is the initialize script to put this script you provided: "this.rawValue = 0 - JS, $.rawValue = 0 - FormCalc"
Also, when I select that cost field in the heading 1 row, there is not a default field in the value tab. The only thing in the value tab
is type: calculated - read only, and calculation script is selected...?
I appreciated your time!
Thanks again.
Views
Total Likes
Here is the .pdf I forgot to attach, thanks!
Views
Total Likes
