3 Replies Latest reply on Jul 7, 2009 2:48 AM by garigantua
    skinng a tree
    garigantua
      Skinng the corner radius of a Tree is proving to be more difficult than it should be unless I'm missing something obvious.  Please see the following for the example.
      <!-- FXG/LibraryExample.mxml -->
      <s:Application
           xmlns:fx="http://ns.adobe.com/mxml/2009"
           xmlns:mx="library://ns.adobe.com/flex/halo"
           <fx:Style>
                @namespace mx "library://ns.adobe.com/flex/halo";
                @namespace s "library://ns.adobe.com/flex/spark";
                .treestyle{
                     /*   Why wouldn't this work  */
                     radius:                    10;
                     radial-stroke:          10;
                     depthColors:          #E6E2AF, #EFECCA ;
                     background-color:     #EFECCA;
                     /*  I can skin the borders of the stroke and fill, but the selection boxes, and added color layers keep their edges */
                     border-skin:           ClassReference("customskins.BorderSkin");
           </fx:Style>
           <fx:Declarations>
                <fx:XMLList id="treeData">
                     <node label="Mail Box">
                          <node label="Inbox">
                               <node label="Marketing"/>
                               <node label="Product Management"/>
                               <node label="Personal"/>
                          </node>
                          <node label="Outbox">
                               <node label="Professional"/>
                          </node>
                          <node label="Spam"/>
                          <node label="Sent"/>
                     </node>
                </fx:XMLList>
           </fx:Declarations>
           <mx:Tree styleName="treestyle" dataProvider="{treeData}" showRoot="false" labelField="@label">
           </mx:Tree>
      </s:Application>
      Is there something I am missing to get radius cornering for the Tree component?  Should I be trying to access the individual highlight FXGs?
        • 1. Re: skinng a tree
          garigantua Level 1
          Sorry, there are some important comments in the code that are not so readable.
          I can skin the borders of the stroke and fill in a custom skin, but the selection boxes, and added color layers keep their edges
          and a screenshot would be helpful...
          • 2. Re: skinng a tree
            Flex harUI Adobe Employee
            I don't believe there are "radius" and "radius-stroke" styles for Tree.  Did you see documentation somewhere?  Did you try "cornerRadius" instead?  That should round the corners, then to deal with selection you'll either have to add paddingTop/Bottom or subclass and override drawHighlightIndicator and drawSelectionIndicator.
            There might be an example on the internet where someone has already done that.
            • 3. Re: skinng a tree
              garigantua Level 1
              Thank you for the help and getting me towards the right direction.  I got parts of the tree skinned correctly, but there are other parts still missing.  Corner-radius doesn't seem to work.
              It seems like a very disjointed process to skin a tree in Flash Builder. Some graphics are overrides, others are skins, and some are not so easy to locate.  Will there be a spark implementation of the Tree component in the future?  I never got into skinning with flash and flex until gumbo.  It's great now, except for skinning halo components.  For that reason, I try to stick with sparks from now on.  The following shows how ugly skinning a halo tree can be.  Thanks.
              Subclassed Tree component
              <mx:Tree xmlns:fx="http://ns.adobe.com/mxml/2009"
                         creationComplete="init()"
                         styleName="roundedTree"
                        contentBackgroundColor="0x0000ff"
                        backgroundColor="0xffff00"
                   object that determines the background color is not connected
                   <fx:Style>
                        .roundedTree{
                             /*   these don't work  */
                             radius:                 10;
                             radial-stroke:        10;
                             corner-radius:          10;
                             border-skin:           ClassReference("skins.BorderSkin");
                   </fx:Style>
                   <fx:Declarations>
                                  </node>
                                  </node>
                             </node>
                        </fx:XMLList>
                   </fx:Declarations>
                   <fx:Script>
                   <![CDATA[
                        import mx.controls.listClasses.IListItemRenderer;
                        private function init():void{
                             dataProvider = treeData;
                             showRoot = false;
                             labelField = "@label";
                             left = 20;
                             top = 20;
                        override protected function drawHighlightIndicator(indicator:Sprite, x:Number, y:Number, width:Number, height:Number, color:uint, itemRenderer:IListItemRenderer):void
                             var g:Graphics = indicator.graphics;
                             g.clear();
                             g.beginFill(0xff0000);
                             g.drawRoundRect(0, 0, width, height, 20, 20);
              //                g.drawRoundRectComplex(0, 0, width, height, 20, 20, 0, 0);
                             g.endFill();
                             indicator.x = x;
                             indicator.y = y;
                        override protected function drawSelectionIndicator(indicator:Sprite, x:Number, y:Number, width:Number, height:Number, color:uint, itemRenderer:IListItemRenderer):void
                             g.clear();
                             g.beginFill(0x0000ff);
              //               g.drawRoundRect(0, 0, width, height, 20, 20);
                             g.endFill();
                             indicator.x = x;
                             indicator.y = y;
                   </fx:Script>
              </mx:Tree>
              custom BorderSkin
                   ADOBE SYSTEMS INCORPORATED
                   Copyright 2008 Adobe Systems Incorporated
                   All Rights Reserved.
                   NOTICE: Adobe permits you to use, modify, and distribute this file
                   in accordance with the terms of the license agreement accompanying it.
              <!--- The Spark skin class for the Halo Border base class. -->
              <local:SparkSkinForHalo xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
                      xmlns:local="mx.skins.spark.*" implements="mx.core.IRectangularBorder">
                  <fx:Script>
                        <![CDATA[
                        import mx.core.EdgeMetrics;
                        import mx.core.IUIComponent;
                        import mx.graphics.RectangularDropShadow;
                      /* Define the skin elements that should not be colorized. */
                      static private const exclusions:Array = []; //"background"
                      override public function get colorizeExclusions():Array {return exclusions;}
                      /* Define the content fill items that should be colored by the "contentBackgroundColor" style. */
                      static private const contentFill:Array = ["bgFill"]; //
                      override public function get contentItems():Array {return contentFill};
                      /* Define the border item. */
                      static private const borderItem:Array = []; //"borderStroke"
                      override protected function get borderItems():Array {return borderItem;}
                      override protected function get defaultBorderItemColor():uint {return 0x696969;}
                        static private const metrics:EdgeMetrics = new EdgeMetrics(1, 1, 1, 1);
                        private var dropShadow:RectangularDropShadow;
                        public function get borderMetrics():EdgeMetrics
                             return metrics;
                        public function get backgroundImageBounds():Rectangle
                             return null;
                        public function set backgroundImageBounds(value:Rectangle):void
                        public function get hasBackgroundImage():Boolean
                             return false;
                        public function layoutBackgroundImage():void
                        override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
                             graphics.clear();
                             super.updateDisplayList(unscaledWidth, unscaledHeight);
                           if (parent && parent is IUIComponent && !IUIComponent(parent).enabled)
                                alpha = 0.5;
                           else
                                alpha = 1;
                             // Draw drop shadow, if needed
                           if (getStyle("dropShadowEnabled") == false ||
                               getStyle("dropShadowEnabled") == "false" ||
                               width == 0 ||
                               height == 0)
                               return;
                           // Create a RectangularDropShadow object, set its properties,
                           // and draw the shadow
                           if (!dropShadow)
                               dropShadow = new RectangularDropShadow();
                           dropShadow.distance = 5;
                           dropShadow.angle = 90;
                           dropShadow.color = 0;
                           dropShadow.alpha = 0.8;
                             dropShadow.blurX = 20;
                             dropShadow.blurY = 20;
                           dropShadow.drawShadow(graphics, x, y, width, height);
                       private function getDropShadowAngle(distance:Number,
                                                           direction:String):Number
                           if (direction == "left")
                               return distance >= 0 ? 135 : 225;
                           else if (direction == "right")
                               return distance >= 0 ? 45 : 315;
                           else // direction == "center"
                               return distance >= 0 ? 90 : 270;
                  </fx:Script>
                  <s:Group left="0" right="0" top="0" bottom="0">
                       <!-- border -->
                        <s:Rect left="0" right="0" top="0" bottom="0" radiusX="20" radiusY="20">
                           <s:stroke>
                               <s:SolidColorStroke id="borderStroke" color="0x00ff00"/>
                           </s:stroke>
                       </s:Rect>
                       <!-- fill -->
                       doesn't work???
                       <s:Rect id="background" left="1" right="1" top="1" bottom="1" radiusX="20" radiusY="20">
                           <s:fill>
                               <s:SolidColor id="bgFill"/>
                           </s:fill>
                       </s:Rect>
                  </s:Group>
               </local:SparkSkinForHalo>
