0 Replies Latest reply on Jul 1, 2009 4:19 PM by cnxFlex
    LCDS 2.6 Clustering Problem
    cnxFlex
      We are trying to get clustering configured for our application so that jms
      topic messages will be handled properly by the servers in the cluster.  We are
      using a hardware load balancer.
      We have set up a default-cluster, using tcp and set the cluster-message-routing
      property to server-to-server.  We see subscription messages being broadcast and
      received between the servers in the cluster.
      >From the server you subscribe to:
      2009-06-30 17:49:01,248 INFO  [STDOUT] [Flex] Sending subscription to peers for
      subscribe? false selector: login='john' or systemwide='true' subtopic: null
      and on the other server:
      2009-06-30 17:49:01,989 INFO  [STDOUT] [Flex] Received subscription from peer:
      10.230.3.4:7800 subscribe? true selector: login='john' or systemwide='true'
      subtopic: null
      The issue is that messages posted to the jms topic don't seem to get sent to
      the other servers in the cluster.  If you are connected to the server handling
      the message you will receive it, otherwise nothing.  Also there is nothing in
      the logs indicating the topic messages are being sent to the other servers.
      Any thoughts on what may be wrong?
      Thanks for your help.
      in services-config.xml:
          <channels>
              <channel-definition id="my-rtmp"
      class="mx.messaging.channels.RTMPChannel">
                  <endpoint url="rtmp://myserver.com:2037"
      class="flex.messaging.endpoints.RTMPEndpoint"/>
                  <properties>
                      <idle-timeout-minutes>0</idle-timeout-minutes>
                  </properties>
              </channel-definition>
          </channels>
          <clusters>
              <cluster id="default-cluster" properties="jgroups-tcp.xml"
      url-load-balancing="false" default="true"/>
          </clusters>
      in messaging-config.xml:
          <adapters>
              <adapter-definition id="actionscript"
      class="flex.messaging.services.messaging.adapters.ActionScriptAdapter" de
      fault="true" />
              <adapter-definition id="jms"
      class="flex.messaging.services.messaging.adapters.JMSAdapter"/>
          </adapters>
          <destination id="topicMessage">
              <properties>
                  <server>
      <cluster-message-routing>server-to-server</cluster-message-routing>
                  </server>
                  <jms>
                      <destination-type>Topic</destination-type>
                      <message-type>javax.jms.ObjectMessage</message-type>
                      <connection-factory>TopicConnectionFactory</connection-factory>
                      <destination-jndi-name>topicMessage</destination-jndi-name>
                      <destination-name>topicMessage</destination-name>
                      <delivery-mode>PERSISTENT</delivery-mode>
                      <message-priority>DEFAULT_PRIORITY</message-priority>
                      <acknowledge-mode>CLIENT_ACKNOWLEDGE</acknowledge-mode>
                      <transacted-sessions>false</transacted-sessions>
                      <initial-context-environment>
                          <property>
                              <name>Context.PROVIDER_URL</name>
                              <value>jnp://server002:1099</value>
                          </property>
                      </initial-context-environment>
                  </jms>
              </properties>
              <channels>
                  <channel ref="my-rtmp"/>
              </channels>
              <adapter ref="jms"/>
          </destination>
