I downloaded the trial version of presenter 7 (and later got an update 7.01)
It worked for about a half hour, while I was recording audio over a powerpoint it came up with a serious error and said to uninstall and re-install.
Did that now when I open powerpoint the presenter tab up top isn't there any longer
Any ideas? When I used it besides the audio quality (could be my mic), looks like this could be a permenant solution for me.
I am using this on a windows vista OS.
thx
Derek
looks like you need to be a local administrator to the computer. Try changing the time.. if that doesn't work.. then you are not a local administrator.
Hope this helps
k
I'm having the same problem. PowerPoint 2007 has apparently disabled the Presenter add in because it is causing "office applications to crash."
Derek
Have you enabled the add in?
One quick way to check in Office 2007 is to go to the Office Button; Select Power Point Option ; Select Add Ins; below the window under manage , select disabled items. If the power point presenter add in is there , select it and select "enable add in".
Hope this helps
