4 Replies Latest reply on Jul 2, 2009 1:51 AM by karthik flex
    How the xml output will be?
    karthik flex
      hi
      For the below table how can the xml should be
      Time
      Phys1
      Phys2
      9.00
      9.15 xxx
      9.25 xxx
      9.30 yyy
      10.00
      10.15 xxx
      I am going in reverse order since my client is not happy with what i did
      My client said i did not ask the exact requirement so
      above table is the exact requirement
      how the xml output should be
      any idea
      karthik.k
        • 1. Re: How the xml output will be?
          sri harsha namala Level 2
          i hope this is the best way
          <result>
          <item Time=""  Phys1=""  Phys2=""  />
          </result>
          • 2. Re: How the xml output will be?
            karthik flex Level 1
            hi namala
            you can see Phys1 having two data that comes one below the other
            does this suit exactly
            any idea
            karthik.k
            • 3. Re: How the xml output will be?
              Oh Sorry Karthik i didnt Notice that two element above Xml will not work i feel
              You should follwo some other Pattern
              May be this helps
              <result>
                    <item>
                        <time>
                             <time></time>
                        </time>
                        <phycs>
                              <phycs></phycs>
                        </phycs>
                   </item>
              </result>
              • 4. Re: How the xml output will be?
                hi namala
                Yes thank you this is what i was looking for
                <result>
                      <item>
                               <time>9:00</time>
                          <phycs >
                                <phycsTime>9:15 </phycsTime>
                               <phycsTime>9:30</phycsTime>
                          </phycs>
                          <phycs>
                                <phycsTime>9:25</phycsTime>
                          </phycs>
                     </item>
                     <item>
                               <time>10:00</time>
                          <phycs >
                          </phycs>
                          <phycs>
                                <phycsTime>10.15</phycsTime>
                          </phycs>
                     </item>
                </result>
                when i used like above it display all in one column should i need to separate two phycs with different names to display in different column
                like below
                          <phycs1>
                               <phycsTime>9.30</phycsTime>
                          </phycs1>
                          <phycs2>
                                <phycsTime>9.25</phycsTime>
                          </phycs2>
                     </item>
                am i right or wrong
                karthik.k
