0 Replies Latest reply on Jul 2, 2009 4:12 AM by sniwas24x7
    Flex Channel Security Error while logging into two different domains from a single Flex app
    sniwas24x7
      hi there
      i need to connect to two different domains from a single flex application. the problem is the domain other than the current hosted domain is unable to login.
      letz say i hosted the application at server A. im able to login to server A. From the existing application i need a login to server B too. The problem comes up here.
      flash security is not allowing login to server B.
      I want to login & access server B from the application running on server A.
      i've loaded both the crossdomain.xml files wherein i allowed access from both the servers.
      our project is dependent on just this task ... if this gets solved ..our application is done.
      now how do i do tht?
      plz i need a solution!!
      ThnQ Sris
