1 Reply Latest reply on Jul 2, 2009 7:42 AM by kglad
    loadMovie with absolute URL
    Scotty T.H.
      Hi there,
      I am very new to Flash and have been going around in circles for days trying to figure this out.
      I can't get swf to loadMovie when on server. I understand I need to use the path relative to the html page.
      Server info:
      Server Name:   server33.000webhost.com
      Home Root (file system path):   /home/a6667948
      Folder to upload files:   public_html
      Have tried this but doesn't work:
      on (release) {
          My_mc.loadMovie("http://server33.000webhost.com/home/a6667948/public_html/Images/Test.swf");
      My html page and 'Images' folder are located inside 'public_html' folder.
      Main.swf and Test.swf are both located inside 'Images'.
      Is there any obvious thing I have done wrong?
      Also: I have got the code below from forum to find the absolute URL... but get the following errors:
      I am desperate to get my flash site working but just aren't savy enough to figure it out. I need your help.
      Thanks in advance.
      ERRORS--
      ';' expected
      public function getAbsoluteUrl(urlInput:String):String {
      Wrong number of parameters;
      loadMovie(getAbsoluteUrl(_root._url) + "_assets/lib.swf");
      CODE--
      var strResult:String = "";
      if(urlInput.indexOf("http://") > -1) //only convert when online
      if(urlInput.indexOf(".swf") > -1) // only convert when an actual .swf file is used
      strResult = urlInput.substring(0, urlInput.lastIndexOf("/")+1); // find absolut path minus filename of .swf
      return strResult;
        • 1. Re: loadMovie with absolute URL
          if you use an absolute url you will have security issues to overcome.  unless you're loading a swf from a different domain, there's no reason to add this additional complexity to your task.
          if you can use a relative path, you need to know the path from the html file that embeds your main swf to the swf you want to load.
