0 Replies Latest reply on Jul 2, 2009 12:28 PM by meshgraphics
    BitmapData.hitTest is Transparent Opacity Enough
    meshgraphics Level 2
      * Just thought I'd give you guys a crack at this before alerting the documentation crew.
      * Are they still accepting comments in livedocs?
      * http://livedocs.adobe.com/flex/3/html/help.html?content=Working_with_Bitmaps_06.html
      * It looks like the doc for BitmapData.hitTest is real screwy.
      * It should probably be called transpFence() - is the pixel transparent enough?
      * The first parm, Point1 is arbitrary. It becomes the de facto (0,0).
      * It is not related to screen coords (see trace 9000).
      * hitTest doesnt care if the obj is on screen. It works on (its own) bitmap data.
      * I've added Bitmap bm3 with transparency on, set to 0x33. Next I added a solid cross of red at (50,50).
      * The pixels at 49 and 51 are transparent enough to fail.
      * You can put this in an ActionScript project and run with debug. The trace is in the Console window.
      package
      import
      flash.display.Bitmap;
      import
      flash.display.BitmapData;
      import
      flash.display.Sprite;
      import
      flash.geom.Point;
      public class BitmapDataHitTest extends
      Sprite
      public function
      BitmapDataHitTest()
      var bmd1:BitmapData = new BitmapData(100, 100, false
      , 0x000000FF);
      var bmd2:BitmapData = new BitmapData(20, 20, false
      , 0x00FF3300);
      // full green totally transparent
      var bmd3:BitmapData = new BitmapData(100, 100, true
      , 0x0000ff00);
      // not added to stage
      var bm3:Bitmap = new
      Bitmap(bmd3);
      // cross maker from previous page
      for (var
      i:uint = 0; i < 100; i++)
      // full opacity is assumed -- wrong!!!
      var
      red:uint = 0xFFFF0000;
      bmd3.setPixel32(50, i, red);
      bmd3.setPixel32(i, 50, red);
      var bm1:Bitmap = new
      Bitmap(bmd1);
      this
      .addChild(bm1);
      // Create a red square.
      var redSquare1:Bitmap = new
      Bitmap(bmd2);
      this
      .addChild(redSquare1);
      redSquare1.x = 0;
      // Create a second red square.
      var redSquare2:Bitmap = new
      Bitmap(bmd2);
      this
      .addChild(redSquare2);
      redSquare2.x = 150;
      redSquare2.y = 150;
      // Define the point at the top-left corner of the bitmap.
      var pt1:Point = new
      Point(0, 0);
      // Define the point at the center of redSquare1.
      var pt2:Point = new
      Point(20, 20);
      // Define the point at the center of redSquare2.
      var pt3:Point = new
      Point(160, 160);
      trace(bmd1.hitTest(pt1, 0xFF, pt2));
      // true
      trace(bmd1.hitTest(pt1, 0xFF, pt3));
      // false
      trace(bmd1.hitTest(new Point(0,4), 0xFF, new
      Point(0,105)));
      trace(bmd1.hitTest(new Point(101,101), 0x00, new
      Point(101,202)));
      Point(201,201)));
      trace(bmd1.hitTest(new Point(9001,101), 0x00, new
      Point(9001,201)));
      trace("-------------------------"
      trace(bmd3.hitTest(new Point(0,0), 0xFF, new
      Point(0,49)));
      Point(0,50)));
      Point(0,51)));
      trace(bmd3.hitTest(new Point(0,0), 0x01, new
      Point(0,49)));
      Point(0,50)));
      Point(0,51)));
      trace("px next to cross is transparent enough?"
      trace(bmd3.hitTest(new Point(0,0), 0x32, new
      Point(0,49)));
      trace(bmd3.hitTest(new Point(0,0), 0x33, new
      Point(0,49)));
      trace(bmd3.hitTest(new Point(0,0), 0x34, new
      Point(0,49)));
