1 Reply Latest reply on Jul 3, 2009 6:27 AM by leybniz
    Instantiation of component in TileList?
    jcrivera07
      When I create a custom component with some public methods and then I set a itemRenderer property of an <mx:TileList to the custom component's name,I'm unable to call the public methods. Does the tilelist not instantiate a component each time it renders an item/object? if it doesn't, is there some way i can call the public methods that I created for that component?
      Sample code:
      <mx:Script>
           <![CDATA[
                    obj1.myCustomFunction();   //can I call something like this ?
      </mx:Script>
      <mx:TileList itemRenderer="myCustomComponent" >
           <mx:Object id="obj1" />
            <mx:Object id="obj2" />
      </mx:TileLis>
        • 1. Re: Instantiation of component in TileList?
          leybniz Level 4
          Nope you can't do that way,
          since your object is Data item itself and itemRenderer is a visual component whose responsibility is to display Data item.
          Generally, you have to put all your logic inside your custom "myCustomComponent" class by overriding data property:
          override public function set data(value:*):void {
               super.data = value;
               // Here you have your obj1, obj2, objN as value
