2 Replies Latest reply on Jul 6, 2009 10:37 AM by Gregory Lafrance
    E4X issue in actionscript
            I have a login page that authenticates the user using the php script. The php script sends an xml <login><result>success</result></login> back to the actionscript,
      In my action script function
      private function loginResult(event:ResultEvent):
        if(event.result.login.result == "success")
           //do something here..
      I m not able to access the result using event.result.login.result.. It was working before.. not sure what happened. If I assign it to a string
      var res:String = event.result.login.result; the variable res is null...Do I need to do anything more?
        • 1. Re: E4X issue in actionscript
          sri harsha namala Level 2
          Hi Bharani,
                                 When you are using E4X as the resultFormat in HttpService ,
                                Directly You can use event.result.result
                              if(event.result.result == "success")
          • 2. Re: E4X issue in actionscript
            Gregory Lafrance Level 6
            Have you confirmed that you are in fact getting back "success" as a result, and that it is coming back in the XML structure you expect?
            What happens when you inspect the event.result object in the FB debugger?
            If this post answers your question or helps, please mark it as such.
