4 Replies Latest reply on Jul 16, 2015 3:54 PM by prifreire
    [JS CS3 WIN] ExportEachPageAsPDF
    cwenet
      Hello,
      I have found this script. Now I want to modify the filename section.
      //ExportEachPageAsPDF.js
      //Exports each page of an InDesign CS document as a separate PDF to
      //a selected folder using the selected PDF export settings.
      //Display a "choose folder" dialog box.
      if(app.documents.length != 0){
          var myFolder = Folder.selectDialog ("Choose a Folder");
          if(myFolder != null){
              myExportPages(myFolder);
      else{
          alert("Please open a document and try again.");
      function myExportPages(myFolder){
          var myPageName, myFilePath, myFile;
          var myDocument = app.activeDocument;
          var myDocumentName = myDocument.name;
          var myPDFPresets = app.pdfExportPresets;
          var myPDFPresetNames = new Array;
          for (i = 0; i < myPDFPresets.length; i++)
              myPDFPresetNames.push(myPDFPresets[i].name);
          var myDialog = app.dialogs.add();
          with(myDialog.dialogColumns.add()){
              with(dialogRows.add()){
                  with(dialogColumns.add()) {
                      staticTexts.add({staticLabel:"Base name:", minWidth:130});
                      var myBaseNameField = textEditboxes.add({editContents:myDocumentName,   minWidth:160});
                  with(dialogColumns.add()){
                      staticTexts.add({staticLabel:"PDF preset: ", minWidth:130});
                      var myPDFPresetsDropdown = dropdowns.add({stringList:myPDFPresetNames,  selectedIndex:0});
          var myResult = myDialog.show({name:"ExportPages"});
          if(myResult == true){
              var myBaseName = myBaseNameField.editContents;
              var myPDFPresetName = myPDFPresetNames[myPDFPresetsDropdown.selectedIndex];
              //Remove the dialog box from memory.
              myDialog.destroy();
              for(var myCounter = 0; myCounter < myDocument.pages.length; myCounter++){
                  myPageName = myDocument.pages.item(myCounter).name;
                  app.pdfExportPreferences.pageRange = myPageName;
      //Generate a filename. /////////////////////////////
                app.findTextPreferences.appliedParagraphStyle = "picture_description";
                app.findTextPreferences.findWhat = '';
               myStory = myDocument.stories;
                myFound = myStory.findText();
             // alert(myFinds[0].contents);
                  myFilePath = myFolder + "/" + myFound[0].contents + ".pdf";
                  myFile = new File(myFilePath);
                  myDocument.exportFile(ExportFormat.pdfType,   myFile, false, myPDFPresets.item(myPDFPresetName));
          else{
              myDialog.destroy();
      On every page there is only 1 paragraph styled with the paragraphstyle "picture_description".
      I want to use the content of this paragraph for the filename for each page.
      please, can someone help me?
      Best regards
      Christoph
