4 Replies Latest reply on Jul 4, 2009 4:01 AM by hkpadobe
    Component Renderer Error
    hkpadobe
      I am using a Component Renderer with the following code:
      <mx:LinkButton
      xmlns:mx="http://www.adobe.com/2006/mxml"
      label="
      Click Here"
      click="(navigateToURL(
      new URLRequest(data.url));)"/>
      and am getting the follwing error:
      The markup in the document following the root element must be well-formed. Test2/src urlRenderer.mxml Unknown 1246607471187 11626
      In my main app file I have a datagrid with 3 columns with the 3rd column using the Renderer.
      Any suggestions.
      J
        • 1. Re: Component Renderer Error
          hkpadobe Level 1
          Here's the main app file and urlRenderer that I am using these were found as examples on the web, but the urlRenderer is giving the error as mentioned earlier.
          Main App
          ?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" backgroundColor="white" backgroundGradientColors="[0xFFFFFF, 0xFFFFFF]">
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          import flash.net.navigateToURL;
          Bindable]
          public var myAC:ArrayCollection = new ArrayCollection([
          {firstName:
          "Jon",lastName:"Hirschi",url:"http://www.flexablecoder.com"},
          {firstName:
          "Tariq",lastName:"Ahmed",url:"http://www.dopejam.com"}
          </mx:Script>
          <mx:DataGrid id="dg" width="700" height="100" dataProvider="{myAC}">
          <mx:columns>
          <mx:DataGridColumn dataField="firstName" headerText="First Name"/>
          <mx:DataGridColumn dataField="lastName" headerText="Last Name"/>
          <mx:DataGridColumn headerText="URL" itemRenderer="urlRenderer"/>
          </mx:columns>
          </mx:DataGrid>
          </mx:Application>
          urlRenderer
          <mx:LinkButton
          label="
          Click Here"
          J
          • 2. Re: Component Renderer Error
            hkpadobe Level 1
            I tried using the following code in my itemRenderer:
            <mx:LinkButton
            label='
            Hello World'
            textDecoration="
            underline" fontWeight="normal"
            click="navigateToURL(
            new URLRequest('http://www.yahoo.com'))" />
            I do see my datagrid when I run my application but the original data in my column is overwritten by 'Hello World'. If I leave the label field out then I don't see any data but if I click on any rows in the column I do navigate to url as shown. If I don't use the itemRenderer than I do see my original data in the column.
            How do I make my original data in the column be visiable and be used as a linkbutton so that I can click on the data to launch the url?
            J
            • 3. Re: Component Renderer Error
              rgadiparthi Level 2
              use
              <mx:DataGridColumn headerText="URL" dataField="url"/>
              instead
              <mx:DataGridColumn headerText="URL" />
              • 4. Re: Component Renderer Error
                hkpadobe Level 1
                Hi rgadiparthi,
                Your advice helped. Can you help with the other issue I have that when I use the urlRenderer the original column names are not shown, so a way of showing them.
                J
